I'm running Eminence under Kodi v17 and it's awesome, I love it!
But I would like to change the info label and media flags under the movies/series.
Is there a way I can change these icons?
They are ok, but a tad to small. So on our TV, from our viewing distance, it's (almost) not possible to see the difference between 1080p and 720p for instance.
If you use the github version of the skin, you can change textures used in the skin.eminence.2/media/indicator/resolution/ folder.
I have installed the skin through Kodi skins. Not the GIT version...
Is that one outdated? Is it better to switch to the GIT version?
Can I easily switch to the GIT version now?
(2018-03-16, 12:20)Panja0 Wrote: [ -> ]Is that one outdated? Is it better to switch to the GIT version?
No. You just can´t change those things after the skin is installed. You need to change it before installation. So we shouldn´t say "the git version is better". It´s more that you need to use that if you want to modify the skin in a way you like.
(2018-03-16, 12:20)Panja0 Wrote: [ -> ]Can I easily switch to the GIT version now?
Yes. Just deinstall the current installation of that skin you have. Download the skin from here:
https://github.com/jurialmunkey/skin.eminence.2
Change the icons at the folder @
jurialmunkey already mentioned above. Then zip everything you downloaded again and install the skin via the "Install from zip"-option.
For reference. This is the folder where the icons are stored:
https://github.com/jurialmunkey/skin.emi...resolution
If you also want to change the icons for the audio formats:
https://github.com/jurialmunkey/skin.emi...ator/audio
Generally any media which is displayed for that skin is stored under the "media"-folder.
Ok, thanks a lot for the explanation.
Sounds logical. Gonna have a look!
