2008-05-04, 20:47
2008-05-04, 21:00
use the executehttpapi() command with sendkey. pydocs and manual links in my signature
2008-05-04, 22:48
this is what im using and i get no responce
responce=xbmc.executehttpapi("SendKey(244)")
244 is the select remote key
also tried http://ipaddress/xbmcCmds/xbmcHttp?comma...ameter=244
and again nothing...
This is the second documented function that doesnt work in XBMC that ive come across
Nuka1195 Wrote:use the executehttpapi() command with sendkey. pydocs and manual links in my signature
2008-05-04, 23:17
ok forget that, unless someone wants to clarify.
When i set xbmc to show keycodes, I get 244 when i press select...however in xbirremote.h then select is defined as 11
Thats why the sendkey failed...because i was sending what xbmc told me was the code for select, when actually it wasnt at all....
2008-05-04, 23:37
244 is the OBC (original button code), whereas internally, microsoft uses the complement of it (255 - OBC).
The keymapping stuff filters this for you - obviously the webserver's sendkey doesn't do this filtering.
Cheers,
Jonathan
Cheers,
Jonathan
2008-05-05, 00:19
okay dokey, i got there in the end, hopefully others will pick this up on a search because its had me perplexed for hours
