I am looking to purchase a mac computer (either macbook or mini) exclusively for the purpose of running OSXBMC. My TV does not have a dvi or hdmi connection so I will need to use component connections with a max resolution of 1080i. What will I need in order to connect a mac to my TV? I have read on some forums that a cable is all that is needed and other say you need some sort of converter box. Any information regarding this issue is greatly appreciated.
Thanks in advance
unfortunately, component out will be difficult as there is no such outlet on the mini or macbook. Does you tv have S-video? because that should be just as good as component and you can buy a simple adapter to go from the mac to S-video out and then an s-video cable to connect. Of course, the sound will come out of the mac, so you will need either a receiver (connect via mini toslink) or speakers plugged into the audio out of the mac...or of course just deal with the mac's internal speakers. I would humbly suggest that you need to do a bit more research before you make a purchase so you know exactly what you're walking into.
I agree more research is needed. I am not interested in s-video quality at this point. It seems there must be a way to do it with and adapter of some kind. I have been using xbmc for quite sometime and it works perfectly outputting component 1080i with it only short coming being it use with HD video. I am really hoping there is a way to do it with a mac as I dont want to give up xbmc for one of those set top box's available.
well, you could get a cable that goes from dvi to coponent like this:
http://sewelldirect.com/DVI-to-Component...le-6ft.asp
the mini has dvi, so you could just use the cable. The macbook has a mini-dvi, so you would need a mini-dvi to dvi adapter and then the cable. I don't have any experience with these cables so I don't know if they work properly, but they probably do.
kalhua Wrote:I agree more research is needed. I am not interested in s-video quality at this point. It seems there must be a way to do it with and adapter of some kind. I have been using xbmc for quite sometime and it works perfectly outputting component 1080i with it only short coming being it use with HD video. I am really hoping there is a way to do it with a mac as I dont want to give up xbmc for one of those set top box's available.
It depends on which hardware platform you buy.
If you go with a mini, then you will need a DVI to component adapter.
If you go with a macbook, you will need a mini-DVI to component adapter.
In either case, you simply need the right adapter for your hardware.
does a mini-dvi to component adapter exist?
renegade Wrote:It depends on which hardware platform you buy.
Thanks for the info, I had read in various forums that a adapter cable will not work. Do you have personal experience with using one? The post I have seen had some age on them so maybe they only applied to an older model mac.
A DVI-to-component and VGA-to-component cable will
not work with the mac. They are only for certain hardwhere that buries the component signal in the DVI port (such as my Sony plasma, and certain panasonics I think).
Component from a Mini Mac is very tricky - I know because I looked at doing this for a while. The only way to achieve it will be to buy a signal converter/transcoder which accepts DVI/VGA input and physically converts the signal into RGB or YUV outputs.
A quick look on google brought back this one, but there will be others in your country -
link
They are quite expensive
I am waiting on a DMI-component cable I have organised from eBay to connect my mini to my LCD TV.
I will let you know how it goes when it arrives!
cjc
It is possible to get component out of a Mac / Mac Mini but it is problematic and/or expensive.
I currently have my Mini using a DVI to VGA adapter and a VGA to component cable. It only works at 480P or 1080i though in my case. It also required purchasing one of the Mac OSX screen programs that let you use screen sizing/timing outside of stock OSX support. On top of all that it took weeks of messing around with it to finally get it working. Even at that it's still not perfect because the screen is oversized for the screen missing about 5% on the top and 2% on the right. I did all this because I wanted to get it working on my 1st HDTV which doesn't have HDMI or DVI so I had to figure out a way to get support via component timings.
A better option is to use a transcoder that takes a DVI signal and converts it to component (or VGA with component timing and a VGA to component cable). They start around $200 and go up from there and many don't support 1920x1080(i or p) at that price point. Component isn't also a typical output of these thing VGA was way more common and not all support component timings.
I messed with the Apple DVI to S-Video adapter as well. Plug and play. No overscan/unscan issues. No black screen or shifting issues. Nice, easy, and painless. The picture doesn't look as crisp as 1080i over component but then the component I have working is shifted to the right and missing a good chunk of the top picture as well.
Better would be to just make do with the s-video until you have something that supports DVI or HDMI input. It's not worth the headache and expense.
Couldn't you let your receiver do the heavy lifting? I send all sorts of inputs into my receiver and it spits out component to my TV. Granted, I'm not doing exactly what you're talking about with converting dvi->component but I wonder if any of the newer receivers that do HDMI switching would output to component. It's easy to go back and forth between HDMI and DVI.
It's worth looking into if you happen to be in the market for a new receiver.
Or I could just be talking out my ass. : )
Good luck!
That is possible, as many of those receivers are just using transcoders. And the cost of the receiver isn't much more then a stand alone transcoder. Most of the one's I've seen though don't down conversion from DVI (HDMI) to Component. I have seen many that do up conversion from component to HDMI, or S-Video to component. In many of those cases the signel still needs to be in the proper format. IE even if it converts from DVI/HDMI down to component it's not going to take just any res, timing, sync so you still need to be outputing something compatible from the Mac.
If you're looking at getting a new receiver to accomplish this is might just be better to get a HDTV with HDMI input(s). They cost nearly nothing now.
Overscan is a bitch. On a regular basis I curse the ATSC for not addressing overscan properly. My (1080i only) HDTV is circa 2003, and is a huge reason that I keep coming back to XBMC.
As far as going DVI->Component, I know that DVI includes all the pins necessary to output a VGA signal, and that most chipsets have the capability to go into a component mode where they stop sending the H&Vsync signals along their own wires and populate the RGB wires with YCbCr. I wonder that nobody has figured out how to turn this on in os-x.
