First of all thank you for this wonderful plugin.
But in the last version, kodi crashes and I start again. This repeats several times. Besides, I'm having instant freezes. I use the plugin directly in Kodi on my RK3229 Android 7 device.
(2019-12-22, 20:29)Skayn Wrote: [ -> ]First of all thank you for this wonderful plugin.
Android 7 is too old, some 7 versons don't work depends on the manufacturer
(2019-12-21, 22:32)pcristi Wrote: [ -> ]Netflix start use left-to-right mark (LRM) as control character for some subtitles language then ‎ is display on began of each subtitles line. "‎Subtitles Line". What should I change to correct it?
it is a InputStream addon problem not here
Anyone able to get smooth Netflix playback on a S922x device with Coreelec? S922x should be more than powerful enough to handle 1080p decoding in software.
I haven't figured out the proper settings for this addon to do that.
Yes, I have smooth NF 1080p (software decoded via inputstream.adaptive) playback on Odroid N2. NF playback depends on CoreElec-Kodi, inputstream.adaptive and widevine versions. It's all discussed on CoreElec forum so search there for the solution. The Netflix addon works OK with default settings, so you maybe have some other problem
(2019-12-24, 15:45)CastagnaIT Wrote: [ -> ] (2019-12-23, 15:26)Essam31 Wrote: [ -> ]Could you try to fix the problem with lrm and rlm in inputstream adaptive? It was working before at least for lrm long time ago and stopped working because of changes made in inputstream apdative or Kodi or something else. See here
https://github.com/peak3d/inputstream.ad...e03b69adba
peak3d tried fixing it properly before but he didn't mange to find a solution.
https://github.com/peak3d/inputstream.adaptive/tree/rlm
It works here in this extension, but I think it differ from inpustream adpative in how the developer dealing with the webvtt subtitles
https://github.com/rsimmons/subadub/comm...066f25b55a
I can give it a try
but i need some video names and what subtitle language that have this problem
Thank you, the subtitles for the Arabic language, for RLM you will find it in "Rick and Morty" in all the episodes and the movie "Bright", for LRM you will find it in "Vikings" and "Teen Wolf" in all the episodes, Right to Left Mark affects on the punctuation marks position in the subtitles.
It looks like this
when it should look like this
(2019-12-23, 09:18)CastagnaIT Wrote: [ -> ] (2019-12-22, 20:29)Skayn Wrote: [ -> ]First of all thank you for this wonderful plugin.
Is the problem really in the Android version? Because the previous version of kodi and plug-in (16.0) works perfectly. I'll have to use this version for a while.
(2019-12-24, 16:29)Essam31 Wrote: [ -> ] (2019-12-24, 15:45)CastagnaIT Wrote: [ -> ] (2019-12-23, 15:26)Essam31 Wrote: [ -> ]Could you try to fix the problem with lrm and rlm in inputstream adaptive? It was working before at least for lrm long time ago and stopped working because of changes made in inputstream apdative or Kodi or something else. See here
I can give it a try
It looks like this
I fixed the problem
now we have to wait for the approval of the inputstream addon maintainer
(2019-12-24, 20:59)CastagnaIT Wrote: [ -> ] (2019-12-24, 16:29)Essam31 Wrote: [ -> ] (2019-12-24, 15:45)CastagnaIT Wrote: [ -> ]I can give it a try
It looks like this
I fixed the problem
Thank you so much, could you upload a compiled version of the fixed inputstream adaptive for Kodi 18.5 Leia for windows 10 so I can test it to make sure that everything is ok?
Hello, is version 16.1 only compatible with python version 3.0.0? I'm using Kodi 18.5 but I'm not able to install latest version because of a conflict with python.. And there are some more add-ons with this problem.. any idea what to do?
It looks like this
I fixed the problem
I installed an older version of Kodi 19 before python 3 downloaded it from here (KodiSetup-20190901)
http://ftp.igh.cnrs.fr/pub/xbmc/xbmc/nig...32/master/
and downloaded your fixed inputstream adaptive from here
https://github.com/peak3d/inputstream.ad...ll-merging
and removed some requires from addon.xml and was able to install it and use it.
After testing, the punctuation marks in the subtitles with LRM like "Vikings" were in the right position, but the punctuation marks in the subtitles with RLM like "Bright" was not in the right position, in Arabic the full stop should be at the left end of the line, it looks like this
and this is the same problem I used to have with inputstream adaptive before when replacing RLM and LRM was working, something more need to be done for getting the punctuation marks in the right position in the Arabic subtitles with RLM.
(2019-12-25, 07:47)Essam31 Wrote: [ -> ] (2019-12-24, 20:59)CastagnaIT Wrote: [ -> ] (2019-12-24, 16:29)Essam31 Wrote: [ -> ]Thank you, the subtitles for the Arabic language, for RLM you will find it in "Rick and Morty" in all the episodes and the movie "Bright", for LRM you will find it in "Vikings" and "Teen Wolf" in all the episodes, Right to Left Mark affects on the punctuation marks position in the subtitles.
It looks like this
I fixed the problem
I kept your fixed version of inputstream adaptive intact and installed this file first to the older version of Kodi 19 and was able to install inputstream adaptive and test it, I used the older version of Kodi 19 because the master branch works only with Kodi 19 and I do not know yet how to compile inputstream adaptive by myself to get a version of your fixed inputstream adaptive working with Kodi 18.5. And the Netflix plugin not working with the latest Kodi 19 with python 3 on windows 10 and this post may take longtime before it get updated and merged.
https://mega.nz/#!pwswFKKD!BINchgBmQSsK_...vyPZNKBcdc
https://github.com/xbmc/xbmc/pull/16850
