I hope someone can help me. An Android box I have has its own in-built Netflix app, which works perfectly. However, if I use my very much preferred method of watching Netflix, which is by using the Kodi add-on, I get a Playback error message, which says;
Netflix returned the following error:
Request failed validation during key exchange
My question is, why can Netflix work satisfactorily through the app yet, on the same box, not work within Kodi? The error message appears on trying to start a stream.
Thank you.
Any idea why Netflix suddenly streams only 960x540??
Can anybody help me find out why tv shows are showing as random numbers whilst playing but movies are ok?
TV Show | Movie | Log
Further to my post above I wonder whether someone could tell me if the following would be possible/worthwhile/disastrous.
Connected to the same TV I have my preferred high spec. Android box (on which the in-built Netflix app works perfectly well but the Netflix add-on inside Kodi will not function at all) as well as a cheap Chinese box, on which, for some reason, Netflix works perfectly well albeit at 540, which is acceptable.
So, if I make a note of the ESN on the Netflix add-on working on the cheap box and manually put it on the Netflix add-on currently not working would that be OK?
(2020-06-17, 19:02)pkscout Wrote: [ -> ]Addon fails at login with a KeyError:
https://paste.kodi.tv/awisikaboh.kodi
glad it's not just me.
This is hysterical; I
JUST installed your Audio Profiles addon and was suspecting it broke Netflix.
Happy (sort of) that disabling AP addon didn't resolve the Netflix issue. AP does
exactly what I wanted it to, re: my post about audio passthrough. Thanks for that!!
Yea, I posted the error to github and like 5 people chimed in with the same issue. All started today. Looks like Netflix made some changes that are starting to get pushed out more widely. That's the challenge with these addons. They are great when they work, but the cat-and-mouse of being an unofficial Netflix app means that you can't really depend on it working. That's not a knock on anybody, that's just what it is.
Getting the keyerror thing as well. This really sucks. Any word on a fix or are we screwed?
(2020-06-18, 07:31)Reckoner89 Wrote: [ -> ]Getting the keyerror thing as well. This really sucks. Any word on a fix or are we screwed?
I am getting the keyerror as well in my android box.
(2020-06-18, 10:48)edragon Wrote: [ -> ] (2020-06-18, 07:31)Reckoner89 Wrote: [ -> ]Getting the keyerror thing as well. This really sucks. Any word on a fix or are we screwed?
I am getting the error on my Khadas Vim3L. NF was working last night. These changes just play into the hands of pirates.
NOTICE -- Netflix has rollout the website changes to all countries
This means the add-on not works, or partially works
From this link you can find a temporary update fix
Before use it remember to read the warning note from the linked post
https://github.com/CastagnaIT/plugin.vid...-645910348
(2020-06-18, 11:52)CastagnaIT Wrote: [ -> ]NOTICE -- Netflix has rollout the website changes to all countries
Thanks for temporarily fixing this problem.
The addon is working again. Just tested it with 'Sunderland 'til I die' S02E01.
I am still on 540p, but that's an other problem and I meanwhile no longer believe that this will change within the next weeks.
(2020-06-17, 23:19)Ainuke Wrote: [ -> ] (2020-06-17, 19:02)pkscout Wrote: [ -> ]Addon fails at login with a KeyError:
This is hysterical; I JUST installed your Audio Profiles addon and was suspecting it broke Netflix.
Happy (sort of) that disabling AP addon didn't resolve the Netflix issue. AP does exactly what I wanted it to, re: my post about audio passthrough. Thanks for that!!
I have the exact same issue! I thought my raspberry pi setup got fried by some very mild power surge but i am experiencing the same issues. I tried reinstalling my system on LibreElec and i cannot even add Fusion.tvaddons.
