2020-11-17, 16:37
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224
2020-11-18, 21:04
Using the 11/17 Build with the 11/16 Kodi v19 daily Win64 build:
Quote:2020-11-18 14:00:55.758 T:11548 ERROR <general>: [plugin.video.netflix (0)] Traceback (most recent call last):
File "C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\resources\lib\services\msl\http_server.py", line 75, in do_GET
data = self.server.msl_handler.load_manifest(int(params['id'][0]))
File "C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\resources\lib\services\msl\msl_utils.py", line 66, in error_catching_wrapper
return func(*args, **kwargs)
File "C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\resources\lib\utils\logging.py", line 164, in timing_wrapper
File "C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\resources\lib\services\msl\msl_handler.py", line 130, in load_manifest
manifest = self._load_manifest(viewable_id, get_esn())
File "C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\resources\lib\services\msl\msl_handler.py", line 162, in _load_manifest
isa_addon = xbmcaddon.Addon('inputstream.adaptive')
RuntimeError: Unknown addon id 'inputstream.adaptive'.
2020-11-18 14:00:55.759 T:9580 ERROR <general>: CCurlFile::FillBuffer - Failed: HTTP returned error 400
2020-11-18 14:00:55.759 T:9580 ERROR <general>: CCurlFile::Open failed with code 400 for http://127.0.0.1:51514/manifest?id=70196252:
2020-11-18 14:00:55.759 T:9580 ERROR <general>: XFILE::CFileCache::Open - failed to open source <http://127.0.0.1:51514/manifest?id=70196252>
2020-11-18 14:00:55.759 T:9580 ERROR <general>: CVideoPlayer::OpenInputStream - error opening [plugin://plugin.video.netflix/play/show/70143836/season/70105286/episode/70196252/?profile_guid=ZX43H4LMLNBQRAIKP52VKEAN3Q]
2020-11-18 14:00:55.759 T:9580 INFO <general>: CVideoPlayer::OnExit()
2020-11-18 14:00:55.776 T:4988 INFO <general>: CVideoPlayer::CloseFile()
2020-11-18 14:00:55.776 T:4988 INFO <general>: VideoPlayer: waiting for threads to exit
2020-11-18 14:00:55.776 T:4988 INFO <general>: VideoPlayer: finished waiting
2020-11-19, 15:35
this means you either don't have inputstream.adaptive enabled or the version is too old
2020-11-19, 21:26
(2020-11-19, 15:35)wsnipex Wrote: [ -> ]RuntimeError: Unknown addon id 'inputstream.adaptive'.
Which comes from where? These aren't new installs. I can go weeks with this add-on working and then either update kodi to a new daily and the nI get these errors. If I try to enable it, it tells me its incompatible....so where do I get it from? Very confusing.
Downloading from here: https://github.com/peak3d/inputstream.adaptive/releases I am unable to install from zip because of an "invalid structure" error I get when trying. I don't know what's going on anymore when it comes to that specific plugin.
2020-11-20, 08:31
it's coming from our repository, but we need peak3d to release a new version because of recent API changes in kodi.
2020-11-21, 19:28
(2020-11-20, 08:31)wsnipex Wrote: [ -> ]it's coming from our repository, but we need peak3d to release a new version because of recent API changes in kodi.
Thanks, that aspect of using this add-on is not clear to end users. It would be nice to outline dependencies and sources
2020-11-21, 19:42
Is there a way to KNOW when that match happens again? Other than trying all the time until it works I mean?
2020-11-22, 09:07
I agree that it's hard to follow and undestand those API changes and it's consequences for certain addons, even for devs. This is especially true late in a release cycle where last minute fixes require API bumps.
But once those have settled(which is has now), it should be a lot smoother.
Please try with the current kodi nightly build, where inputstream.adaptive should work again.
2020-11-22, 15:41
(2020-11-22, 09:07)wsnipex Wrote: [ -> ]I agree that it's hard to follow and undestand those API changes and it's consequences for certain addons, even for devs. This is especially true late in a release cycle where last minute fixes require API bumps.Thanks for the heads up. While I do have a "working" inputstream.adaptive (I think because it downloaded), now a new symptom has risen...if I attempt to play a video, kodi straight up crashes. Haven't had Kodi crash like that in a long while. Have tried thrice so far.
2020-11-22, 15:48
Quote:2020-11-22 08:46:02.887 T:11604 INFO <general>: [plugin.video.netflix (3)] The debug logging level is set as "Disabled"
2020-11-22 08:46:02.888 T:9388 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:02.892 T:13212 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:03.130 T:9388 INFO <general>: CPythonInvoker(18, C:\Users\Danial\AppData\Roaming\Kodi\addons\script.embuary.helper\plugin.py): script successfully run
2020-11-22 08:46:03.380 T:9388 INFO <general>: Python interpreter stopped
2020-11-22 08:46:03.399 T:13212 INFO <general>: CPythonInvoker(17, C:\Users\Danial\AppData\Roaming\Kodi\addons\script.embuary.helper\plugin.py): script successfully run
2020-11-22 08:46:03.633 T:13212 INFO <general>: Python interpreter stopped
2020-11-22 08:46:04.030 T:11604 INFO <general>: CPythonInvoker(19, C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\addon.py): script successfully run
2020-11-22 08:46:05.106 T:11604 INFO <general>: initializing python engine.
2020-11-22 08:46:06.673 T:11604 INFO <general>: CPythonInvoker(19, C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\addon.py): script successfully run
2020-11-22 08:46:08.314 T:11604 INFO <general>: initializing python engine.
2020-11-22 08:46:09.899 T:11604 INFO <general>: CPythonInvoker(19, C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\addon.py): script successfully run
2020-11-22 08:46:10.485 T:4516 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:10.636 T:4516 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:10.653 T:4516 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:10.715 T:11604 INFO <general>: initializing python engine.
2020-11-22 08:46:11.156 T:11604 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:11.157 T:11604 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:11.158 T:11604 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:11.159 T:11604 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:11.159 T:11604 ERROR <general>: EXCEPTION: Invalid setting type
2020-11-22 08:46:11.159 T:11604 WARNING <general>: [script.module.inputstreamhelper] Widevine update check was made on 2020-11-03 22:01
2020-11-22 08:46:11.325 T:11604 INFO <general>: CPythonInvoker(19, C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\addon.py): script successfully run
2020-11-22 08:46:11.325 T:11604 INFO <general>: CPythonInvoker(19, C:\Users\Danial\AppData\Roaming\Kodi\addons\plugin.video.netflix\addon.py): waiting on thread 8868
2020-11-22 08:46:11.349 T:12880 INFO <general>: VideoPlayer::OpenFile: plugin://plugin.video.netflix/play/movie/80997613/?profile_guid=ZX43H4LMLNBQRAIKP52VKEAN3Q
2020-11-22 08:46:11.350 T:12140 INFO <general>: Creating InputStream
2020-11-22 08:46:11.351 T:12140 INFO <general>: AddOnLog: inputstream.adaptive: SetVideoResolution (3840 x 2160)
2020-11-22 08:46:11.352 T:12140 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting C:\Program Files\Kodi\addons\inputstream.adaptive\
2020-11-22 08:46:11.469 T:13152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:11.532 T:13152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2020-11-22 08:46:12.100 T:11480 ERROR <general>: [plugin.video.netflix (0)] fix_locale_languages: missing mapping conversion for locale "zh-Hans"
2020-11-22 08:46:12.100 T:11480 ERROR <general>: [plugin.video.netflix (0)] fix_locale_languages: missing mapping conversion for locale "zh-Hant"
2020-11-22 08:46:12.103 T:12140 INFO <general>: AddOnLog: inputstream.adaptive: Successfully parsed .mpd file. #Periods: 1, #Streams in first period: 12, Type: VOD, Download speed: 0.0000 Bytes/s
2020-11-22 08:46:12.780 T:12140 INFO <general>: Creating Demuxer
2020-11-22, 15:54
happened to me too yesterday. after I clicked on "full sync" of my profile, Kodi crashed.
Then each time I opened it, when the netflix background process tried to load, crash again.
I had to very quickly open kodi, disable the addon and then I was able to use kodi.
I uninstalled the addon completely and then reinstalled. That fixed the issue.
2020-11-22, 17:03
(2020-11-22, 15:54)orenmi Wrote: [ -> ]happened to me too yesterday. after I clicked on "full sync" of my profile, Kodi crashed.
Yeah, I just tried uninstalling the Netflix add-on and removing the settings and all of that. Still crashes Kodi when I try to actually play a video. Weird.
2020-11-22, 20:21
Even for myself problem, From today as I try to play a video Kodi closes automatically
2020-11-22, 22:36
(2020-11-22, 20:21)marcopt Wrote: [ -> ]Even for myself problem, From today as I try to play a video Kodi closes automatically
Problem seems to be with Inputstream Adaptive 2.6.6 on Windows.
If rolled back to 2.6.5, then it doesnt crash kodi but then some videos dont play, the fix for which is in 2.6.6!
2020-11-23, 00:57
(2020-11-22, 22:36)gujal Wrote: [ -> ]Thanks I followed your advice I went back to v2.6.5 now everything works ,,, we hope they resolve soon with the new version(2020-11-22, 20:21)marcopt Wrote: [ -> ]Anche per me problema, da oggi mentre provo a riprodurre un video Kodi si chiude automaticamente
