(2018-10-30, 13:37)webmaher Wrote: [ -> ]Hi
i have problem with Netflix addon… when installing Kodi goes shut down and then the only chance to start again is delete all netflix folders and files
Kodi-Netflix log file
Thanks for the log file, but it doesn't show much that I can see. Maybe you can try deleting the Add-on settings from userdata but thats about all I can suggest.
everytime when this happen I must then deleted every Netflix single files if I wanna start Kodi again… On Sony Android TV and Windows 10 everything work perfect… i really dont know why this not working and crushed Kodi...
Hello !
I have been using the netflix add-on on a raspberry Pi running libreelec nightly with Kodi 18.
It was working fine, except that I could access only videos "original from Netflix" (the other menus were jut waiting forever). But that was fine with me.
But now, I cannot read any videos, it just says "netflix error" when I click the menu (even the "Netflix originals" one).
I followed the step to produce a log file (I am techsavy but no expert in linux or Kodi).
So I activated the logs and I rebootde the raspberry Pi and tried to enter netflix addon, but now it doesn't even enter netflix addon. It says error.
Here is my log file.
https://paste.kodi.tv/zogudalacu.kodi
Hopefully something useful can be spotted there !
/glatering
Can't see any error in that log file, maybe try to create a clean one with just the netflix Add-on.
Hey guys I was just wondering if I'm doing something wrong or if that's just not a feature yet. I can watch a tv show or movie from netflix in kodi just fine, but if i connect to my netflix account through the web or phone app I don't see that show/movie updated. Am I doing something wrong ?
The addon doesn't really provide 2-way communication between itself and Netflix. It sends login data and navigational commands but doesn't send information like watch history.
The FAQ on github states that 4K HDR Netflix should work in Android. However, I run a Win10 machine. Does it also work in Windows? Or does Kodi itself first need more HDR support in Windows?
Have been using this netflix addon for the past week in Kodi 18 beta3 on my Shield and it works pretty well. Only hassle so far is I am using the Chroma skin and if I create a widget for my Netflix My List it works for a little while, but later in the day it just has a blank widget that doesnt do anything. I think even restarting kodi doesnt reload it - I have to go into skin settings and reinstall the widget. I wonder if thats a skin issue or the netflix addon issue? My other widgets work fine.
The Only thing can see that it is not working with is Mediacodec, Its strange that the amazon prime plugin works just fine!!!
Hey everyone,
one of the devs of the addon here. Missed this thread and just wanted to let you know I'm now following here as well.
Your feedback on the PR linked by debutanker is greatly appreciated. Because this is a major overhaul, we wanted some feedback before merging and rolling it out as a release.
docwra and @
Ismadder1 : Your issues have been fixed with the latest commits. Happy bug hunting
I just loaded this up on my windows 10 system. Works great. Only comments are it does not default to a specific profile. Always comes up to choose one. Also once i choose profile, it does not give me option for My List. I have to go into All TV Shows then i can find My List option.
Thanks for the great work.
