(2018-11-06, 02:18)mzup Wrote: [ -> ]I just loaded this up on my windows 10 system. Works great. Only comments are it does not default to a specific profile. Always comes up to choose one. Also once i choose profile, it does not give me option for My List. I have to go into All TV Shows then i can find My List option.
Thanks for the great work.
You can enable auto-login for a profile by going into the context menu on the profiles screen. The issue with My List not showing up is confirmed. I thought I had it fixed, but it seems I was wrong. Might have to tweak that some more.
Hi, is there a way to change the preselected german audio for avoiding to change it manually every time?
(2018-11-05, 15:49)Ismadder1 Wrote: [ -> ]Ive Done a Clean Install of Kodi Leia Beta 5, Will Not PlayBack Video, Heres The Log https://pastebin.com/nEzpQj6F
Successful instanciated media_drm: 0x9492e570, deviceid: , systemId: 4445 security-level: L3
You will most likely not be able to play netflix streams on a L3 device. You can try to reduce MaxSecureResolution to something < HD in inputstream.adaptive settings.
I thought I did enable the auto login, but in looking again I see it wasn't. Losing my mind I guess.
thanks again
It Plays the Kodi Amazon VOD add-on at 480, It Plays Google netflix App 480p which it should do as be Widvine LVL3, But It does not play on the Kodi App. Ive lowered the input to 480. This is current error im getting. Error: bytearray(b'1&\xbfsq\^\x8f8\xf6\xb4F\x05Q\xc8\x9f\xd7\xc0\xd7~*\x11\xa6\x93\x10L\xb6\xdf\x16\x93\xab\xe2') is not JSON serializable.
https://github.com/asciidisco/plugin.vid...beta.6.log
(2018-11-06, 18:54)Ismadder1 Wrote: [ -> ]It Plays the Kodi Amazon VOD add-on at 480, It Plays Google netflix App 480p which it should do as be Widvine LVL3, But It does not play on the Kodi App. Ive lowered the input to 480. This is current error im getting. Error: bytearray(b'1&\xbfsq\^\x8f8\xf6\xb4F\x05Q\xc8\x9f\xd7\xc0\xd7~*\x11\xa6\x93\x10L\xb6\xdf\x16\x93\xab\xe2') is not JSON serializable.
L3 devices should play at least 480p in any case. That specific error you reported is fixed in beta7, albeit inputstream.adaptive now complaining (in at least one reported case).
I don't have an Android system to test with
so I'm especially dependent on your feedback on this.
Loaded up beta 8 and see the My List and others but getting error KeyError: content.
Quick question, why doesn't the Netflix stream cache/buffer forward like other streams? It almost seems to play like a live stream?
same here, see my previous posts.
(2018-10-30, 22:34)glattering Wrote: [ -> ]Hello !
I have been using the netflix add-on on a raspberry Pi running libreelec nightly with Kodi 18.
It was working fine, except that I could access only videos "original from Netflix" (the other menus were jut waiting forever). But that was fine with me.
But now, I cannot read any videos, it just says "netflix error" when I click the menu (even the "Netflix originals" one).
I followed the step to produce a log file (I am techsavy but no expert in linux or Kodi).
So I activated the logs and I rebootde the raspberry Pi and tried to enter netflix addon, but now it doesn't even enter netflix addon. It says error.
Here is my log file.
https://paste.kodi.tv/zogudalacu.kodi
Hopefully something useful can be spotted there !
/glatering
(2018-11-07, 01:46)mzup Wrote: [ -> ]Loaded up beta 8 and see the My List and others but getting error KeyError: content.
same, beta 6 or 7 worked just fine, anyone know how to downgrade?
edit: uninstalling addon and settings and then reinstalling seems to have fixed it
Uninstall and remove settings then reinstall beta 8 also worked for me.
thanks
Beta 10 is now available. See my latest comment on the PR at
https://github.com/asciidisco/plugin.vid...x/pull/519
Android playback should hopefully work now.
(2018-11-08, 14:44)mzup Wrote: [ -> ]Uninstall and remove settings then reinstall beta 8 also worked for me.
thanks
In beta 10 there is an option in the settings under Advanced, that lets you purge the contents of the cache. This should fix those issues. Don't know why they are occurring though. A debug log would be helpful.
