Even 1080 was possible with my RPi without any issues on the latest 14 beta 18 before everything went bad a few days ago...
still no go … same error..thanks "essam315" for your help
(2018-11-28, 23:56)FlashOne Wrote: [ -> ] (2018-11-28, 23:21)essam315 Wrote: [ -> ]Use this release, its working for me now
https://mega.nz/#!5p8lDIiR!oqx8IdNwLrfYV...BD1ZVp6cHE
Following all the hard work on gitHub thread, thank you very much guys!
Latest release works almost fine, it also fix a problem I had when trying to play some particular tv shows where only audio used to works while screen was black and flickering.
I just can't get more than 720 resolution, where with previous releases everything was played on 1080.
Shouldn't be InputStream Adaptive related because it works regularly with other addon (i.e. Amazon VOD). My setup is Leia v18 rc1 Win7.1.
Am I missing some setting?
1080P is working for me now with this release on Windows 10.
https://mega.nz/#!IhlHwCbY!lQn0ZUqRcEekU...NdHPhS26Bs
Getting german audio and some german subtitles with the latest build. Is there a way to permanently set the addon to English audio?
(2018-11-30, 02:14)essam315 Wrote: [ -> ] (2018-11-29, 16:20)C.O.D. Wrote: [ -> ]Even 1080 was possible with my RPi without any issues on the latest 14 beta 18 before everything went bad a few days ago...
Unfortunetely not for me - what bitrates have you set in Inputstream Adaptive?
I had 0.13.20 before so what's different to the version you provided?
(2018-11-30, 02:16)essam315 Wrote: [ -> ] (2018-11-28, 23:56)FlashOne Wrote: [ -> ] (2018-11-28, 23:21)essam315 Wrote: [ -> ]Use this release, its working for me now
Tried again and again from scratch uninstalling both InputStream 2.3.12 (newest release) and Netflix plugins but with no luck, 720p is always the max resolution I can get...
This works finally for me again. Thank you for your diligent effort !
(2018-11-30, 12:50)essam315 Wrote: [ -> ] (2018-11-30, 11:56)C.O.D. Wrote: [ -> ] (2018-11-30, 02:14)essam315 Wrote: [ -> ] 1080P is working for me now with this release on Windows 10.
This commit, did not change anything, try the movie "Bright" it worked for me in 1080p.
You're right, seems that only certain movies or tv shows play in 1080p but not all the same ones which previously did.
I'm starting to suspect that could be some issue related to specific countries.
Could you please make a try with "12 years a slave"? It now play for me at 720p, while I'm sure it used to be at 1080p
(2018-11-30, 13:30)FlashOne Wrote: [ -> ] (2018-11-30, 12:50)essam315 Wrote: [ -> ] (2018-11-30, 11:56)C.O.D. Wrote: [ -> ]Unfortunetely not for me - what bitrates have you set in Inputstream Adaptive?
Sorry, this movie is not in the Netflix of my country now.
Could you please try with tv shows like "The Crown", "Better Call Saul", "Disenchantment", "Narcos: Mexico" or movies like "Sulla mia pelle" or "Jack Whitehall: At Large". All these used to play fine for me in 1080p but not anymore.
