Sorry I meant just breaking bad doesn't load at all
(2018-12-04, 13:58)popeye2468 Wrote: [ -> ]It's not playing at all just sits trying to load it and if I try to stop the stream it will freeze Kodi all together
Try the instructions here, not all the contents will be played in 1080P, if you can not play the contents in 720P on Firefox on Windows 10, you most likely will not be able to play them on Kodi with Netflix plugin 0.13.21 until now in 1080P, do you have any android devices?
https://forum.kodi.tv/showthread.php?tid...pid2796484
I do have a firestick upstairs but my main machine is a pc running libreelec
Oops breaking bad now playing and in full 1080p
But the film secret life of pets still in 480p
(2018-12-04, 14:17)popeye2468 Wrote: [ -> ]Oops breaking bad now playing and in full 1080p
Any movies with 720 HD tag, will be played in 480P, try "Cloud Atlas" it should be played in 1080P. any movies with 1080 HD tag will be played in 1080P like "loober", at least that is what is happen with me, this problem might get fixed by the developers in the future, especially by this developer, bookmark this link.
https://github.com/asciidisco/plugin.vid...x/pull/519
With this release you can play 4K on android devices.
https://github.com/caphm/kodi-repo/blob/...beta18.zip
Yep mines exactly the same as yours
I just don't understand why suits and some movies
Are only 480p, the quality is still good but no where near as good as the real 1080
As for android I'm not a fan, im an x86 man hence my libreelec, I tried windows but constant crashes etc.
Android is just too slow even had a shield, maybe in a few years or will be good, but nothing will beat an x86 architecture at the minute for me
why you think that android too slow...on my Sony android TV Kodi with Netflix addon work very good and i can watch 4k HDR movies and series without problems…
If you dont have android TV, Nvidia shield also not bad choice if you want play 4k HDR...
(2018-12-04, 16:52)popeye2468 Wrote: [ -> ]Yep mines exactly the same as yours
Suits is 1080P, read here.
https://github.com/asciidisco/plugin.vid...issues/184
This developer had found a way to play all the videos in 1080P before but it stopped now and might find one again.
https://github.com/asciidisco/plugin.vid...-437427435
So whats the consensus with Netflix and hardware acceleration, because its great and all that Netflix support is finally here but if its 480p quality its basically useless. If I have to result to use Android or a Windows PC, then that is really still a work around. I really would love to have at minimum 1080p, but preferably 4k HDR under CoreELEC/LibreELEC.
So just curious would running windows allow full 1080p netflix on movies?
popeye2468, yes play fine 1080p with audio multi channel.
Should i be using a different version as with official 0.13.21
secret life of pets still 480p
(2018-12-05, 02:29)popeye2468 Wrote: [ -> ]Should i be using a different version as with official 0.13.21
To play Secret Life of Pets in 1080P in Windows use Windows 10 App for Netflix.
https://help.netflix.com/en/node/55763
(2018-12-05, 02:53)essam315 Wrote: [ -> ] (2018-12-05, 02:29)popeye2468 Wrote: [ -> ]Should i be using a different version as with official 0.13.21
To play Secret Life of Pets in 1080P in Windows use Microsoft Edge or Windows 10 App for Netflix.
How to play video from kodi use Web Browser ?
