Hello @
essam315 ,
I've already installed the v14, Beta18, so and "upgrade" to thr v14 won't help.
I've cleared the caches, too.
Any other ideas?
Can you send me this app so i can check it?
(2018-12-10, 15:25)webmaher Wrote: [ -> ]@daw13id my Kaon MKSTB 6020 android box have Widevine L1 but cant play anything… i got also error widevine cryptokey...see LOG file
But i found mobi app where I can play all... but only 480p quality…
Can you please send me this app so i can check if it works on my device?
I dont remember which version i use because i deleted….
Here you have all versions… try maybe with first in year 2017... if no go then go back... I used this only to get ESN number… for me the only options is Netflix addon for Kodi because I cant watching without subtitles… and of course at least HD quality… I get lucky to have Sony Android TV where addon work almost perfect and I can watch in 4k HDR quality...
I've installed the latest 0.13.21 on Kodi 18.0 RC3 nightly running on Ubuntu 18.04 (I have to use a nightly to enable the inputstream addon)
When I start the netflix addon it reports this error to the log:
10:18:15.829 T:139950749713344 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
10:18:16.995 T:139948596209408 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.URLError'>
Error Contents: <urlopen error [Errno 111] Connection refused>
File "/home/kodi/.kodi/addons/plugin.video.netflix/addon.py", line 33, in <module>
NAVIGATION.router(paramstring=REQUEST_PARAMS)
File "/home/kodi/.kodi/addons/plugin.video.netflix/resources/lib/utils.py", line 60, in wrapped
result = func(*args, **kwargs)
File "/home/kodi/.kodi/addons/plugin.video.netflix/resources/lib/Navigation.py", line 123, in router
options = self.before_routing_action(params=params)
File "/home/kodi/.kodi/addons/plugin.video.netflix/resources/lib/Navigation.py", line 867, in before_routing_action
'method': 'is_logged_in'}))
File "/home/kodi/.kodi/addons/plugin.video.netflix/resources/lib/Navigation.py", line 1053, in call_netflix_service
data = urllib2.urlopen(full_url).read()
File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python2.7/urllib2.py", line 429, in open
response = self._open(req, data)
File "/usr/lib/python2.7/urllib2.py", line 447, in _open
'_open', req)
File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 1228, in http_open
return self.do_open(httplib.HTTPConnection, req)
File "/usr/lib/python2.7/urllib2.py", line 1198, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 111] Connection refused>
I can see that call_netflix_service() in Navigation.py is failing, as far as I can tell it's calling a local netflix proxy that is supposed to be listening on localhost, the default port is 8001 (I can't see this overridden anywhere) but nothing is listening on this port. I've tried re-installing a totally clean OS in a new VM with a clean install of kodi and get the same error.
Any suggestions on what might stop that from running?
Netflix add-on currently causes Kodi to crash on Android TV.
Here is a logcat of the incident.
--------- beginning of crash
12-11 16:53:44.631 24882 25010 F libc : Fatal signal 6 (SIGABRT), code -6 in tid 25010 (Thread-12)
12-11 16:53:44.632 9853 9853 W : debuggerd: handling request: pid=24882 uid=10157 gid=10157 tid=25010
12-11 16:53:44.720 25135 25135 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
12-11 16:53:44.720 25135 25135 F DEBUG : Build fingerprint: 'Sony/BRAVIA_ATV3_4K_EU/BRAVIA_ATV3_4K:7.0/NRD91N.S139/1.6.0.56.29.1.00:user/release-keys'
12-11 16:53:44.720 25135 25135 F DEBUG : Revision: '0'
12-11 16:53:44.720 25135 25135 F DEBUG : ABI: 'arm'
12-11 16:53:44.720 25135 25135 F DEBUG : pid: 24882, tid: 25010, name: Thread-12 >>> org.xbmc.kodi <<<
12-11 16:53:44.720 25135 25135 F DEBUG : signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
12-11 16:53:44.724 25135 25135 F DEBUG : Abort message: 'art/runtime/java_vm_ext.cc:470] JNI DETECTED ERROR IN APPLICATION: JNI NewByteArray called with pending exception android.media.MediaDrm$MediaDrmStateException: Failed to restore keys: DRM vendor-defined error: -2949'
12-11 16:53:44.724 25135 25135 F DEBUG : r0 00000000 r1 000061b2 r2 00000006 r3 00000008
12-11 16:53:44.724 25135 25135 F DEBUG : r4 8b102978 r5 00000006 r6 8b102920 r7 0000010c
12-11 16:53:44.724 25135 25135 F DEBUG : r8 00000000 r9 b31e9c5c sl 000019e7 fp b31af5af
12-11 16:53:44.724 25135 25135 F DEBUG : ip 0000000b sp 8b100ea0 lr b4522447 pc b4524ca4 cpsr 080b0010
12-11 16:53:44.847 25135 25135 F DEBUG :
12-11 16:53:44.847 25135 25135 F DEBUG : backtrace:
12-11 16:53:44.847 25135 25135 F DEBUG : #00 pc 00049ca4 /system/lib/libc.so (tgkill+12)
12-11 16:53:44.847 25135 25135 F DEBUG : #01 pc 00047443 /system/lib/libc.so (pthread_kill+34)
12-11 16:53:44.847 25135 25135 F DEBUG : #02 pc 0001d745 /system/lib/libc.so (raise+10)
12-11 16:53:44.847 25135 25135 F DEBUG : #03 pc 00019291 /system/lib/libc.so (__libc_android_abort+34)
12-11 16:53:44.847 25135 25135 F DEBUG : #04 pc 00017034 /system/lib/libc.so (abort+4)
12-11 16:53:44.847 25135 25135 F DEBUG : #05 pc 003170b5 /system/lib/libart.so (_ZN3art7Runtime5AbortEv+252)
12-11 16:53:44.847 25135 25135 F DEBUG : #06 pc 000b4779 /system/lib/libart.so (_ZN3art10LogMessageD2Ev+864)
12-11 16:53:44.848 25135 25135 F DEBUG : #07 pc 002370e9 /system/lib/libart.so (_ZN3art9JavaVMExt8JniAbortEPKcS2_+1664)
12-11 16:53:44.848 25135 25135 F DEBUG : #08 pc 002372db /system/lib/libart.so (_ZN3art9JavaVMExt9JniAbortVEPKcS2_St9__va_list+58)
12-11 16:53:44.848 25135 25135 F DEBUG : #09 pc 000ca11b /system/lib/libart.so (_ZN3art11ScopedCheck6AbortFEPKcz+46)
12-11 16:53:44.848 25135 25135 F DEBUG : #10 pc 000c9d07 /system/lib/libart.so (_ZN3art11ScopedCheck11CheckThreadEP7_JNIEnv+362)
12-11 16:53:44.848 25135 25135 F DEBUG : #11 pc 000c8d1f /system/lib/libart.so (_ZN3art11ScopedCheck22CheckPossibleHeapValueERNS_18ScopedObjectAccessEcNS_12JniValueTypeE+26)
12-11 16:53:44.848 25135 25135 F DEBUG : #12 pc 000c81fb /system/lib/libart.so (_ZN3art11ScopedCheck5CheckERNS_18ScopedObjectAccessEbPKcPNS_12JniValueTypeE+802)
12-11 16:53:44.848 25135 25135 F DEBUG : #13 pc 000cf471 /system/lib/libart.so (_ZN3art8CheckJNI17NewPrimitiveArrayEPKcP7_JNIEnviNS_9Primitive4TypeE+452)
12-11 16:53:44.848 25135 25135 F DEBUG : #14 pc 01652114 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (_ZNK12CJNIMediaDrm10removeKeysERKNSt6__ndk16vectorIcNS0_9allocatorIcEEEE+60)
12-11 16:53:44.848 25135 25135 F DEBUG : #15 pc 01614148 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (_ZN3DRM22CMediaDrmCryptoSession12CloseSessionEv+68)
12-11 16:53:44.848 25135 25135 F DEBUG : #16 pc 01614580 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (_ZN3DRM22CMediaDrmCryptoSession10RemoveKeysEv+52)
12-11 16:53:44.848 25135 25135 F DEBUG : #17 pc 00c72334 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #18 pc 01793be8 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #19 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.848 25135 25135 F DEBUG : #20 pc 01795044 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #21 pc 01793b90 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #22 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.848 25135 25135 F DEBUG : #23 pc 01795044 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #24 pc 01793b90 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #25 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.848 25135 25135 F DEBUG : #26 pc 0178e1c4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalCodeEx+1704)
12-11 16:53:44.848 25135 25135 F DEBUG : #27 pc 01794fa4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #28 pc 01793b90 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #29 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.848 25135 25135 F DEBUG : #30 pc 01795044 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.848 25135 25135 F DEBUG : #31 pc 01793b90 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #32 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.849 25135 25135 F DEBUG : #33 pc 01795044 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #34 pc 01793b90 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #35 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.849 25135 25135 F DEBUG : #36 pc 01795044 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #37 pc 01793b90 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #38 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.849 25135 25135 F DEBUG : #39 pc 0178e1c4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalCodeEx+1704)
12-11 16:53:44.849 25135 25135 F DEBUG : #40 pc 01881760 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #41 pc 01718db4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyObject_Call+116)
12-11 16:53:44.849 25135 25135 F DEBUG : #42 pc 01723a54 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #43 pc 01718db4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyObject_Call+116)
12-11 16:53:44.849 25135 25135 F DEBUG : #44 pc 01762fc8 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #45 pc 0175dcbc /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #46 pc 01718db4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyObject_Call+116)
12-11 16:53:44.849 25135 25135 F DEBUG : #47 pc 01795120 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #48 pc 01793b74 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #49 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.849 25135 25135 F DEBUG : #50 pc 0178e1c4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalCodeEx+1704)
12-11 16:53:44.849 25135 25135 F DEBUG : #51 pc 01881760 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #52 pc 01718db4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyObject_Call+116)
12-11 16:53:44.849 25135 25135 F DEBUG : #53 pc 01723a54 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #54 pc 01718db4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyObject_Call+116)
12-11 16:53:44.849 25135 25135 F DEBUG : #55 pc 01792840 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_CallObjectWithKeywords+212)
12-11 16:53:44.849 25135 25135 F DEBUG : #56 pc 017215dc /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyInstance_New+132)
12-11 16:53:44.849 25135 25135 F DEBUG : #57 pc 01718db4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyObject_Call+116)
12-11 16:53:44.849 25135 25135 F DEBUG : #58 pc 01795120 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.849 25135 25135 F DEBUG : #59 pc 01793b74 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.850 25135 25135 F DEBUG : #60 pc 01790448 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalFrameEx+8172)
12-11 16:53:44.850 25135 25135 F DEBUG : #61 pc 0178e1c4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyEval_EvalCodeEx+1704)
12-11 16:53:44.850 25135 25135 F DEBUG : #62 pc 01881760 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
12-11 16:53:44.850 25135 25135 F DEBUG : #63 pc 01718db4 /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so (PyObject_Call+116)
If it helps anyone, I am using version 0.13.19 on Kodi 18 RC1 on windows, Shield android TV, and on Raspberry Pi3 libreelec. I think I have mine all set to 720p if that makes a difference. The kids /other users section work as well. I got it from a post here maybe a week ago.
(2018-12-11, 12:32)murphya Wrote: [ -> ]I've installed the latest 0.13.21 on Kodi 18.0 RC3 nightly running on Ubuntu 18.04 (I have to use a nightly to enable the inputstream addon)
FYI I found the issue on the source git repo. It was missing the pycryptodome dependency, which is meant to be installed as a dependancy by kodi but shows as "not available". Strangely even though this is a vital component this is not a fatal failure for the install process, it reports success.
By running `
pip install --user pycryptodomex` on the command line netflix now works.
Everything is working great except some movies/tvshows are not offered in 1080 only 540 SD. Why is that? I'm using nvidia shield and in the bottom right of the skin it shows either 1080, 720, or 540 for resolution of the show. The 540 res is usually on the more popular movies like black panther and thor. Why is this and what can I do to fix it?
(2018-12-14, 05:47)r0ck0 Wrote: [ -> ]Everything is working great except some movies/tvshows are not offered in 1080 only 540 SD. Why is that? I'm using nvidia shield and in the bottom right of the skin it shows either 1080, 720, or 540 for resolution of the show. The 540 res is usually on the more popular movies like black panther and thor. Why is this and what can I do to fix it?
If you are using Netflix plugin 0.13.21, some of the movies and TV shows with the tag 540 are actually in 1080P when you play them, and the movies with the tag 720 are usually in 480p.
Unfortunately the caphm version 0.14 beta 18 does not work anymore on the Millhouse alfa builds of LibreElec for raspberry. Returned to the 0.13.21 and that works (after a de-install with all settings removed).
Using the 0.14beta18 pops a dialog saying so much as not ok and look in the log...
Tried to find something in the debug-log but it does not give anything useful? (would post it full but the netflix strings contain alot of privacy sensitive data...)
Think these are relevant bits:
14:44:54.655 T:1524618096 DEBUG: [plugin.video.netflix (0)] Executing POST request to
http://www.netflix.com/api/msl/NFCDCH-LX...m/manifest
14:44:55.325 T:1524618096 DEBUG: [plugin.video.netflix (0)] Request took 0.090017s
14:44:55.325 T:1524618096 DEBUG: [plugin.video.netflix (0)] Request returned response with status 200
14:44:55.330 T:1524618096 DEBUG: [plugin.video.netflix (0)] Received encrypted chunked response
14:44:55.351 T:1524618096 ERROR: [plugin.video.netflix (0)] Full MSL error information:
14:44:55.358 T:1524618096 ERROR: [plugin.video.netflix (0)] {"result": {"errorDetails": "No message available", "errorDisplayMessage": "", "data": {"DEFINITION": {"PRESENTATION_TYPES": {"1": "PRIMARY", "0": "COMMENTARY", "2": "ASSISTIVE"}, "OPEN_CONNECT_SIGNALS": {"IS_HTTPS_SUPPORTED": "false"}, "OFFLINE_DOWNLOAD_DESCRIPTOR": {"QUALITY": "DEFAULT"}, "SUPPORTS_PREVIEW_CONTENT": true, "NETWORK_TYPE": "UNKNOWN", "INCOMPATIBLE_MEDIA_INCLUDED": false, "BRANCHED_CONTENT_REQUESTED": false, "trackId": 0, "CUSTOMER_DATA": {"RESTRICTED_BY_TESTER_TYPE": false, "STREAM_QUALITY": "UNSPECIFIED", "EXPERIENCE_TYPE": "regular",
... snip ...
"REQUEST_CONTEXT_CLOCK_TIME": 1544881495, "REQUEST_CONTEXT_DEVICE_TYPE_ID": 781}, "errorExternalCode": 2206, "errorSubCode": 1331}, "success": false}
Anyone else experiencing this and hopefully has a solution?
(The pycrypto lib is supposed to be in the alfa builds and can not be installed with pip for that matter).
(2018-12-15, 16:09)Huey Wrote: [ -> ]Unfortunately the caphm version 0.14 beta 18 does not work anymore on the Millhouse alfa builds of LibreElec for raspberry. Returned to the 0.13.21 and that works (after a de-install with all settings removed).
14:44:54.655 T:1524618096 DEBUG: [plugin.video.netflix (0)] Executing POST request to http://www.netflix.com/api/msl/NFCDCH-LX...m/manifest
... snip ...
Try this fixed 0.14.1 it should work for you (not fixed by me, all credit goes to "jakermx" from GitHub), uninstall everything first (this is not an official release, i just gave the fixed release a new number to differentiate it from 0.14.0 beta 18).
https://mega.nz/#!ptcx1aZR!rVPoAd-WIApD1...GySB2fHof0
(2018-12-14, 06:49)essam315 Wrote: [ -> ] (2018-12-14, 05:47)r0ck0 Wrote: [ -> ]Everything is working great except some movies/tvshows are not offered in 1080 only 540 SD. Why is that? I'm using nvidia shield and in the bottom right of the skin it shows either 1080, 720, or 540 for resolution of the show. The 540 res is usually on the more popular movies like black panther and thor. Why is this and what can I do to fix it?
I'm using a 14.beta you posted, forgot which one. It fixed the issue with adding/removing items from my list. I didn't check with 13.21 which I was using if the SD played in HD. Anyway to combine the best of both?
(2018-12-15, 20:43)r0ck0 Wrote: [ -> ] (2018-12-14, 06:49)essam315 Wrote: [ -> ] (2018-12-14, 05:47)r0ck0 Wrote: [ -> ]Everything is working great except some movies/tvshows are not offered in 1080 only 540 SD. Why is that? I'm using nvidia shield and in the bottom right of the skin it shows either 1080, 720, or 540 for resolution of the show. The 540 res is usually on the more popular movies like black panther and thor. Why is this and what can I do to fix it?
Almost everything important in 0.13.21 is in 0.14.0 beta, use this one 0.14.1, in 0.14.0 the tags are right, 540 means 540, to play all Netflix contents in 1080P you must use Netflix app for windows 10 (maybe other official apps in other devices work on 1080P for all the contents).
(2018-12-15, 20:59)essam315 Wrote: [ -> ] (2018-12-15, 20:43)r0ck0 Wrote: [ -> ] (2018-12-14, 06:49)essam315 Wrote: [ -> ]If you are using Netflix plugin 0.13.21, some of the movies and TV shows with the tag 540 are actually in 1080P when you play them, and the movies with the tag 720 are usually in 480p.
https://github.com/Essam315/plugin.video...0.14.1.zip
Thanks, using an nvidia shield if that makes any difference.
