This was working just fine for me, Until it updated to v14. Now, All I get is Green for video. Audio plays fine
I've tried many changes in the settings for the passed couple days, to no avail.
Windows 10 pro x64
Kodi v18.2
I'm getting a black screen with no audio, using either version of the addon on LibreElec 9.0.1 w/ Kodi 18.1 on a Raspberry Pi 3. The video acts as if it's playing with the seekbar moving but I get a black screen with no audio. I've tried messing with all of the addon settings and Inputstream settings to no avail. What's curious is that I have Kodi 18.1 running on my Windows 7 PC and Netflix works with no problems. I can't figure out for the life of me what the issue is. I feel like I've tried everything. I've seen other people report that they have Netflix running on their Pis.
(2019-05-04, 05:51)lordkramdar Wrote: [ -> ]I'm getting a black screen with no audio, using either version of the addon on LibreElec 9.0.1 w/ Kodi 18.1 on a Raspberry Pi 3. The video acts as if it's playing with the seekbar moving but I get a black screen with no audio. I've tried messing with all of the addon settings and Inputstream settings to no avail. What's curious is that I have Kodi 18.1 running on my Windows 7 PC and Netflix works with no problems. I can't figure out for the life of me what the issue is. I feel like I've tried everything. I've seen other people report that they have Netflix running on their Pis.
Raspberry Pi is a problematic device
the only solution is:
-in kodi settings: settings/player/videos disable: OMXPlayer
-in netflix expert settings disable HEVC and VP9, Rpi cpu is not very powerful
-if 1080p not fluid set inputstream adaptative max resolution to 720p due to weak cpu
The video not appearing issue i solved myself by disabling everything that was enabled in expert settings.
The only other problem im now having is that some shows/episodes its not picking up the audio
One example is "street food", episode 2.
if someone could test that episode and see if its a netflix/add on issue, or if its an issue at my end before i start troubleshooting..
Hi, I'll get the following message after a while:
Playback error
The addon encountered the following error:
locale_id
Error dails have been written to the Kodi logfile.
Logfile:
2019-05-03 22:32:14.578 T:1778266992 WARNING: Previous line repeats 4 times.
2019-05-03 22:32:14.578 T:1778266992 WARNING: [plugin.video.netflix (0)] Canceling previous library update: duration >6 hours
2019-05-03 22:32:14.894 T:1454535536 WARNING: [plugin.video.netflix (-1)] Backing file does not exist or is not readable
2019-05-03 22:32:25.876 T:1454535536 WARNING: Attempt to use invalid handle -1
2019-05-03 22:32:29.142 T:1936871440 WARNING: Previous line repeats 4 times.
2019-05-03 22:32:29.142 T:1936871440 ERROR: GetDirectory - Error getting /storage/netflix/movies/Anthony Jeselnik Fire in the Maternity Ward (2019)/Anthony Jeselnik Fire in the Maternity Ward (2019).strm
2019-05-03 22:32:29.703 T:1531331440 NOTICE: Indigo NOTICE: Checking for Malicious scripts
2019-05-03 22:32:38.656 T:1454535536 ERROR: NEWADDON Unknown Video Info Key "runtime"
2019-05-03 22:32:38.700 T:1936871440 NOTICE: VideoPlayer::OpenFile: /storage/netflix/movies/Anthony Jeselnik Fire in the Maternity Ward (2019)/Anthony Jeselnik Fire in the Maternity Ward (2019).strm
2019-05-03 22:32:38.702 T:1202025328 NOTICE: Creating InputStream
2019-05-03 22:32:38.738 T:1202025328 ERROR: GetDirectory - Error getting /usr/lib/kodi/addons/inputstream.adaptive/
Netflix 0.14.1 from castagnait
Rpi3, Leia 18.1
(2019-05-04, 21:02)bierbaron_2 Wrote: [ -> ]Error dails have been written to the Kodi logfile.
We like only full log files (not just the bits that you think are interesting), and we like them presented via a pastebin website to keep our forum clean.
Also, if that reference in your log file is towards the Indigo add-on, please note that no support will be given to Kodi setups with
banned addons (wiki) in them as per our
forum rules (wiki).
(2019-05-04, 20:10)stefive83 Wrote: [ -> ] (2019-05-04, 05:51)lordkramdar Wrote: [ -> ]I'm getting a black screen with no audio, using either version of the addon on LibreElec 9.0.1 w/ Kodi 18.1 on a Raspberry Pi 3. The video acts as if it's playing with the seekbar moving but I get a black screen with no audio. I've tried messing with all of the addon settings and Inputstream settings to no avail. What's curious is that I have Kodi 18.1 running on my Windows 7 PC and Netflix works with no problems. I can't figure out for the life of me what the issue is. I feel like I've tried everything. I've seen other people report that they have Netflix running on their Pis.
Awesome, thanks man, disabling OMXPlayer is what made it work for me.
(2019-05-05, 10:20)Piethenk Wrote: [ -> ]When trying to open the netflix add-on I get a pop up from osmc saying "Netflix error". Here are the logs. https://paste.kodi.tv/ujuralamaf.kodi
I fixed that by uninstalling the addon then setting up the repository as described on the first post, reinstalling the addon from there, then disabling everything under Advanced Settings in the Netflix addon, and finally a reboot.
Can someone test for me
Street Food - Episode 2
Street Food - Episode 3
and see if they have audio. So that I can establish if its a netflix/add-on issue, or if its an issue with my device. Most programs Im having no problems with but theres a handful (street food and a few episodes of terrace house) where i get no audio
I am a bit bandwidth restricted on my odroid c2/libreelec 9 setup. Is it possible to configure this add on to ask for 2-channel audio instead of multichannel? Furthermore, is it possible to ask for H.265 video for plain HD resolutions (ie 720p, 1080p)?
EDIT: Some notes after playing a bit with this addon.
1) If I disabled DD plus support in the expert settings, the addon downloads 2-channel variants of the stream, instead of multichannel one:
2019-05-06 00:31:15.708 T:3414160240 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
Now here's the funny stuff: the very first time I made this configuration change, the clip played back perfectly. On the second episode I tried to play though, no audio was coming out! Here's the funny part: while playing the same clip, if I switch audio to another language (german for example) in the stream, it plays in stereo perfectly. Switch back to the English 2-ch audio stream and it is muted again!!!
2) Enabling H.265 in the expert settings (only the H.265 option selected and not the two sub-options) produces some inputstream errors in the log. Hence it seems that it is not doable at the moment.
All in all, I must find out why I'm experiencing with issue with the "muted" 2-channel sound...
I’m confused. In the latest release with HQ audio+Atmos, which audio stream is the highest quality? The first one? (default track)
Addon installs fine on my Mac mini, I can browse videos and everything, but I can't get Netflix to play a video. It just shows the animated circle forever or doesn't react when I hit play. Anything I can try?
(2019-05-04, 21:07)Klojum Wrote: [ -> ] (2019-05-04, 21:02)bierbaron_2 Wrote: [ -> ]Error dails have been written to the Kodi logfile.
Also, if that reference in your log file is towards the Indigo add-on, please note that no support will be given to Kodi setups with banned addons (wiki) in them as per our forum rules (wiki).
My apologies. I was not aware the add-on you mentioned was banned. I deleted it.
Here is the log:
https://paste.kodi.tv/zemefobiki.kodi
The problem occours after a while. After a reboot I can use Netflix, but then not anymore
