anyone knows if there is a similar addon for Amazon prime video?
Same problem on nvidia shield after update to android 9, netflix not working(some suggest is inputstream, but all other that use it works like amazon youtube etc)
(2019-08-07, 09:37)Devil-Strike Wrote: [ -> ]Same problem on nvidia shield after update to android 9, netflix not working(some suggest is inputstream, but all other that use it works like amazon youtube etc)
No need to write all the "me too" postings. It's broken for everyone using the shield pie update.
Any fix for the 540p movies? I'm getting almost all the movies at no more than 540p, whilst the series are properly delivered at 1080p or 2k. This kind of makes the plugin unusable for me
^^ actually pardon my dumbness, it looks like I'm just that lucky and having a ton of 540p movies on 'my list'
Any chance of sorting genres by ratings, rather than alphabetically?
For those using the KODi Addon primarily for auto refresh rate on nvidia Shield, there's an app that let's you use the original apps (Netflix, Amazon Prime Video, Movies Anywhere etc) and have auto refresh rate with those:
https://www.nvidia.com/en-us/geforce/for...ogle-play/
Works pretty well so far!
Sorry if this has been asked before but couldn't find anything. I have an issue with some series like "Money Heist" , I export the show but it only shows the 1st and 2nd season . I have zero idea what happens there.. Anyone that has the same issue or a solution ? Thanks in advance
(2019-08-11, 01:24)Darkmage40 Wrote: [ -> ]Sorry if this has been asked before but couldn't find anything. I have an issue with some series like "Money Heist" , I export the show but it only shows the 1st and 2nd season . I have zero idea what happens there.. Anyone that has the same issue or a solution ? Thanks in advance
Money Heist only has two seasons, in 3 parts.
Netflix recut season 1 into two parts. Instead of 15 episodes over 60 minutes each (typically 75 minutes) they recut the first season into 45 minutes pieces and released in two parts, which is why they call season 2 "Part 3"
TVDB listing
https://www.thetvdb.com/series/la-casa-d...easons/all
Original broadcast page Antena 3
https://www.antena3.com/series/casa-de-papel/
Just installed the addons and login successfully. Video lag, how can I solve?
where is the location of the exported tv/movie info in Android (shield)?
I cant get the export media to work.
(2019-08-11, 23:15)orenmi Wrote: [ -> ]where is the location of the exported tv/movie info in Android (shield)?
found a way. on my kodi, for some reason, when trying to add media source, clicking on root folder didnt do anything.
I went to file manager in kodi, browse to the addon folder and added the Movie/TV source from there.
(2019-08-11, 15:31)matteo2 Wrote: [ -> ]Just installed the addons and login successfully. Video lag, how can I solve?
1st posts asks for a debug log for all issues.
