Everything has been going well for several weeks now but tonight I started getting error messages. I updated from the repository in hopes that would work and it appeared that my login information got blown out, so I re-entered that, but it's still throwing errors.
My logfile is as follows:
https://paste.kodi.tv/ozisumuzip
(2019-08-25, 04:58)starslayer74 Wrote: [ -> ]Everything has been going well for several weeks now but tonight I started getting error messages. I updated from the repository in hopes that would work and it appeared that my login information got blown out, so I re-entered that, but it's still throwing errors.
There are a lot of errors also from other plugin
makes me think that something is not working in the internet connection
so seem that in the first startup it failed to copy the necessary databases
for some reason the track is now deleted from the log due too many trying...
to keep your things as is, you need to copy manually the two database files, from the netflix addon folder,
to the folder: userdata\addon_data\plugin.video.netflix\database\
Or else you can delete the addon with settings, and reinstall it,
then, if at the first error start, if you don't try to enter the credentials several times, perhaps a trace of the problem remains in the log
in any case it would be useful to first enable kodi debug info
I appear to be getting the same issue, logfile below.
https://paste.kodi.tv/icoyiwufiv.kodi
(2019-08-25, 10:52)konel Wrote: [ -> ] (2019-08-25, 04:58)starslayer74 Wrote: [ -> ]Everything has been going well for several weeks now but tonight I started getting error messages. I updated from the repository in hopes that would work and it appeared that my login information got blown out, so I re-entered that, but it's still throwing errors.
I need to have a log extracted this way:
delete addon and settings
install then wait for message that appears of netflix at the top
without opening addon, extract log
maybe so i can see the cause
Hey peeps, got a issue getting error: Only Bytes strings can be passed to C Code
Any ideas or solutions?
(2019-08-25, 11:38)stefive83 Wrote: [ -> ]I need to have a log extracted this way:
I reinstalled the add-on and below is the logfile up to the point where the "background services started" banner came up.
https://paste.kodi.tv/ihozohocis.kodi
I then restarted kodi and was able to login, when i tried to play a video I got an error, see below logfile.
https://paste.kodi.tv/axetemoduj.kodi
Restarted kodi again and now all is working...
https://paste.kodi.tv/apubiwehus.kodi
As of just now, my Netflix plugin has auto-updated to version 0.15.0 (Raspbian Stretch, Kodi 18) and now I just get the following error
https://pastebin.com/qmGmwgdg
This hapens when it's trying to start the background services, or when I try to browse or play videos.
(2019-08-25, 18:08)FatGerman Wrote: [ -> ]As of just now, my Netflix plugin has auto-updated to version 0.15.0 (Raspbian Stretch, Kodi 18) and now I just get the following error
you need to update to 15.1
Best solution is first complete uninstall addon and all settings and then install last new version and then everything work as before...
Thanks again @stefive83 for this great addon
(2019-08-25, 18:48)stefive83 Wrote: [ -> ] (2019-08-25, 18:08)FatGerman Wrote: [ -> ]IAs of just now, my Netflix plugin has auto-updated to version 0.15.0 (Raspbian Stretch, Kodi 18) and now I just get the following error
Thanks. I can't see a 15.1, 15.0 is the newest version I'm being offered. I have CastagnaIT repo enabled, is there a different repo I should be using?
(2019-08-25, 19:04)FatGerman Wrote: [ -> ] (2019-08-25, 18:48)stefive83 Wrote: [ -> ] (2019-08-25, 18:08)FatGerman Wrote: [ -> ]IAs of just now, my Netflix plugin has auto-updated to version 0.15.0 (Raspbian Stretch, Kodi 18) and now I just get the following error
i can't find 15.1 either.....
add on updated itself today, nothing but sqlite errors since. (same if used master from github)
reverted to last daily 20190708 fixed it, but thats pretty darned old, actually its mega old..
my other device that never updated to 15.1 is fine on 15.0
but the device that went to 15.1, sqlite error on 15.1, still the error if i revert to 15.0, but fine on 14.6
cant post a log.
will try put clean log together later and post on git
edit: complete removal and zapping all user data (i backed up database and library and zapped them back in after) seems to have sorted it
(2019-08-25, 09:26)stefive83 Wrote: [ -> ] (2019-08-25, 04:58)starslayer74 Wrote: [ -> ]Everything has been going well for several weeks now but tonight I started getting error messages. I updated from the repository in hopes that would work and it appeared that my login information got blown out, so I re-entered that, but it's still throwing errors.
It definitely was not the internet - everything else was working fine on my setup.
I did find out that my fiance updated the password to Netflix, so I corrected that, but I was still getting the error. I came back to the thread and saw the post about 15.1 so I downloaded that and updated, but it still gave me the error. So I uninstalled totally, and then reinstalled, and I'm still getting an error.
I fixed the issue with the other addon so that shouldn't be an issue going forward - here is my latest logfile, the only thing not working on my setup is Netflix -
https://paste.kodi.tv/nevuneqafa
