Full Version: Favorits on Home screen
Hi, sorry for this stupid question, maybe I´m blind: I want to get the Favorits as a menue item at the same menue on top level where all other key functions like e.g. music, video etc. are available. I can´t find a section withing the skin section where I can enable this. For sure it´s possible like in each skin, but where can I configurre this?
Another problem which I couldn´t get up and running: I want to add a menue item on top level where are just all stations from radio addon will be available which are part of "my stations". How can I do this?
In advance many thanx for each help.
hi tabesp,
where are you from? Maybe if you are from germany my videos can help you:
Add a Main Menu Section: https://www.youtube.com/watch?v=Zr9XWE1_uqw
Remember: If you can mark an item as favourite you can add it to main menu.
Hi, thank you for referring your Youtube Video. I´m German, that´s right, so I could follow your instructions.
Just one question: There is a Video where you are explaining how to setup Amazon Prime Video in Kodi 17. Is this working today again or is it outdated? I´ve heard about that Amazon has changed its streaming format, so I´m not sure.
Have a great weekend!
(2018-03-18, 00:59)tabesp Wrote: [ -> ]Hi, sorry for this stupid question, maybe I´m blind: I want to get the Favorits as a menue item at the same menue on top level where all other key functions like e.g. music, video etc. are available. I can´t find a section withing the skin section where I can enable this. For sure it´s possible like in each skin, but where can I configurre this?
Hi tabesp.
Here's a step-by-step guide to adding custom categories: https://kodi.wiki/view/Add-on:Rapier#Cre...m_category
Below there's a guide to adding custom submenus.
(2018-03-18, 00:59)tabesp Wrote: [ -> ]Another problem which I couldn´t get up and running: I want to add a menue item on top level where are just all stations from radio addon will be available which are part of "my stations". How can I do this?
The radio stations can maybe be added as submenu items to a custom category?
If you add each radio station in "my stations" as a favourite, and add these favourites as submenus, it should work.
7 submenus for each category are available.
(2018-03-18, 12:06)tabesp Wrote: [ -> ]ust one question: There is a Video where you are explaining how to setup Amazon Prime Video in Kodi 17.
Outdated, now its just more easy.
Just install the Addon and log in to Amazon. The Addon will do all itself. (Downloading Widevine, aktivating inputstream Addon)
You need at last Kodi Laia for it.
Here is the german information in first post:
https://www.kodinerds.net/index.php/Thre...ant-Video/
