Full Version: Pictures menu
I understand that pictures menu not working as tv and movies menus, I didn't find a 'pictures' content while trying to change the folder content type.
Is there a way to load and view images from attached external hard drive so it will behave like movies and TV shows library and not as file explorer?
(And why would I need different menu that acts like file explorer? I can do the same with the actual Kodi file explorer..).
What am I missing?
The is no Library for Pictures.
...but an addon is available
None of the available add-ons do the job, I think.
I have a lot of pictures on attached external HDD and all the addons I saw is working with clouds websites (like Google, Dropbox) or some other web sites.
Can you recommend on add-on that works with external HDD?
I think peppe_sr was most likely referring to the MyPicsDB addon see https://forum.kodi.tv/showthread.php?tid=133905
Many thanks!
I will try it!
