2018-03-19, 09:34
Hello there,
I want to set up a mediaplayer with android running kodi.
It has to play media (Photos, Videos) via NFS from a NAS.
Here is my Problem:
I found that playing media via the wrapper does not function quite well if the source is mounted via NFS.
Due to the wrapper set as default it is quite annoying to press and hold the file only to select "open with" and select the non-default mediaplayer.
Therefore I want to either change the default player or completely uninstall wrapper.
The only Problem is in dont have and I dont find any information online to do any this.
And no I would rather not to use SMB.
I would appreciate if someboby could help me out.
xyz-axel
Here is my Problem:
xyz-axel
