Full Version: Remote control Xbox and kodi
I want to buy remote control to use in my Xbox one x instead of regular Xbox controller.
1. Is official Xbox media remote works good with Xbox apps ?
2. And of course, is it currently work with Kodi app?
If you can recommend on another remote 20-40 $) that works better with all Xbox app, works great with Kodi app and control tv (need only on , off and volume) it will be nice.
I use the 30 to 40 dollar logitech harmony.....works fine. Perfect world for me would be able to pair a firetv remote. I have one paired to my shield and works great
I am thinking maybe buying the official xbox one media media remote, did someone tried it with Kodi app?
I am sure it works fine.....but better to have remote that controls other things at same time at similar price.
I am sure it works fine.....but better to have remote that controls other things at same time at similar price. Plus being able to remap keys via remote software instead of kodi xml
A harmony and Kodi Add-On Keymap Editor works great.
The official Xbox One Media remote works perfectly, I have it.
I'm using this remote.  https://www.oneforall.com/remotes/urc6440-simple-4.html
Button:
TV -> TV, PVR -> Xboxone+Kodi, DVD ->HTPC, Extra -> sound system
Remote with the Xbox is working fine
