2018-03-19, 18:59
I am running Kodi over an Apple FireTV stick and I could rather easily scrape my 7000+ videos (movies and TV series) over an SMB share connected to a router with an USB port.
I have then started to add my personal homemade videos, which consist of some Divx, many SVCD and DVD (all created during 1999-2004).
For all of them I have created ad-hoc poster and fanart images, plus an NFO file. I have instructed Kodi to use the local scraper (.nfo), and haven't set any checkmarks (no recursive scanning, no nothing).
The DivX are all recognized immediately, the SVCD are also recognized (although no menu is displayed - the file plays as is) but for the DVD it's a fight.
They are added to the library but sometimes, they play, and sometimes, Kodi can't find them.
Look at the two examples below, which refer to the same video:
15:42:13.002 T:18446744072511990544 NOTICE: VideoPlayer: Opening: smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.IFO
15:42:13.002 T:18446744072511990544 DEBUG: LinuxRendererGL: Cleaning up GL resources
15:42:13.003 T:18446744072541411800 DEBUG: Thread VideoPlayer start, auto delete: false
15:42:13.005 T:18446744072541411800 NOTICE: Creating InputStream
15:42:13.010 T:18446744072513684128 INFO: CActiveAESink::OpenSink - initialize sink
15:42:13.010 T:18446744072513684128 DEBUG: Draining Audio
15:42:13.011 T:18446744072513684128 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
15:42:13.011 T:18446744072513684128 DEBUG: CAESinkAUDIOTRACK::Initialize requested: sampleRate 44100; format: AE_FMT_FLOAT; channels: 2
15:42:13.012 T:18446744072513684128 DEBUG: Updated SampleRate: 32000 Distance: 108900
15:42:13.012 T:18446744072513684128 DEBUG: Updated SampleRate: 44100 Distance: 0
15:42:13.012 T:18446744072513684128 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
15:42:13.013 T:18446744072513684128 DEBUG: Minimum size we need for stream: 30104
15:42:13.014 T:18446744072513684128 DEBUG: Created Audiotrackbuffer with playing time of 170.657596 ms min buffer size: 60208 bytes
15:42:13.019 T:18446744072513684128 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 60208 m_frames: 3763 m_frameSize: 8 channels: 2
15:42:13.019 T:18446744072513684128 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
15:42:13.020 T:18446744072513684128 DEBUG: Output Device : android
15:42:13.020 T:18446744072513684128 DEBUG: Sample Rate : 44100
15:42:13.020 T:18446744072513684128 DEBUG: Sample Format : AE_FMT_FLOAT
15:42:13.020 T:18446744072513684128 DEBUG: Channel Count : 2
15:42:13.020 T:18446744072513684128 DEBUG: Channel Layout: FL,FR
15:42:13.020 T:18446744072513684128 DEBUG: Frames : 3763
15:42:13.021 T:18446744072513684128 DEBUG: Frame Size : 8
15:42:13.025 T:18446744072541411800 INFO: msg: libdvdnav: Using dvdnav version 5.0.4
15:42:13.028 T:18446744072541411800 DEBUG: msg: libdvdread: Couldn't find device name.
15:42:13.028 T:18446744072513653736 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
15:42:13.042 T:18446744072541411800 DEBUG: Previous line repeats 1 times.
15:42:13.042 T:18446744072541411800 DEBUG: CSMBFile::Open - opened smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.IFO, fd=10001
15:42:13.072 T:18446744072541411800 INFO: msg: libdvdnav: Unable to open device file smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001).
15:42:13.073 T:18446744072541411800 DEBUG: msg: libdvdnav: vm: dvd_read_name failed
15:42:13.073 T:18446744072541411800 INFO: msg: libdvdnav: vm: DVD Title:
15:42:13.073 T:18446744072541411800 INFO: msg: libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions:
15:42:13.073 T:18446744072541411800 INFO: msg: 1
15:42:13.073 T:18446744072541411800 INFO: msg: 2
15:42:13.073 T:18446744072541411800 INFO: msg: 3
15:42:13.074 T:18446744072541411800 INFO: msg: 4
15:42:13.074 T:18446744072541411800 INFO: msg: 5
15:42:13.074 T:18446744072541411800 INFO: msg: 6
15:42:13.074 T:18446744072541411800 INFO: msg: 7
15:42:13.074 T:18446744072541411800 INFO: msg: 8
15:42:13.075 T:18446744072541411800 DEBUG: msg:
15:42:13.082 T:18446744072541411800 DEBUG: CSMBFile::Open - opened smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.VOB, fd=10000
Here above, the video played OK, while ten seconds after, it all went wrong
15:42:24.774 T:18446744072511990544 NOTICE: VideoPlayer: Opening: smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.IFO
15:42:24.774 T:18446744072511990544 DEBUG: LinuxRendererGL: Cleaning up GL resources
15:42:24.775 T:18446744072530431864 DEBUG: Thread VideoPlayer start, auto delete: false
15:42:24.780 T:18446744072530431864 NOTICE: Creating InputStream
15:42:24.781 T:18446744072513684128 INFO: CActiveAESink::OpenSink - initialize sink
15:42:24.781 T:18446744072513684128 DEBUG: Draining Audio
15:42:24.783 T:18446744072513684128 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
15:42:24.783 T:18446744072513684128 DEBUG: CAESinkAUDIOTRACK::Initialize requested: sampleRate 44100; format: AE_FMT_FLOAT; channels: 2
15:42:24.783 T:18446744072513684128 DEBUG: Updated SampleRate: 32000 Distance: 108900
15:42:24.783 T:18446744072513684128 DEBUG: Updated SampleRate: 44100 Distance: 0
15:42:24.784 T:18446744072513684128 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
15:42:24.785 T:18446744072513684128 DEBUG: Minimum size we need for stream: 30104
15:42:24.785 T:18446744072513684128 DEBUG: Created Audiotrackbuffer with playing time of 170.657596 ms min buffer size: 60208 bytes
15:42:24.793 T:18446744072513684128 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 60208 m_frames: 3763 m_frameSize: 8 channels: 2
15:42:24.793 T:18446744072513684128 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
15:42:24.793 T:18446744072513684128 DEBUG: Output Device : android
15:42:24.793 T:18446744072513684128 DEBUG: Sample Rate : 44100
15:42:24.794 T:18446744072513684128 DEBUG: Sample Format : AE_FMT_FLOAT
15:42:24.794 T:18446744072513684128 DEBUG: Channel Count : 2
15:42:24.794 T:18446744072513684128 DEBUG: Channel Layout: FL,FR
15:42:24.794 T:18446744072513684128 DEBUG: Frames : 3763
15:42:24.794 T:18446744072513684128 DEBUG: Frame Size : 8
15:42:24.800 T:18446744072513653736 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
15:42:24.802 T:18446744072530431864 DEBUG: Previous line repeats 1 times.
15:42:24.802 T:18446744072530431864 INFO: msg: libdvdnav: Using dvdnav version 5.0.4
15:42:24.814 T:18446744072530431864 DEBUG: msg: libdvdread: Couldn't find device name.
15:42:24.821 T:18446744072530431864 INFO: msg: libdvdread: Could not open smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.IFO with libdvdcss.
15:42:24.821 T:18446744072530431864 INFO: msg: libdvdreadVDOpenFilePath:dvdinput_open smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.IFO failed
15:42:24.827 T:18446744072530431864 INFO: msg: libdvdread: Could not open smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.BUP with libdvdcss.
15:42:24.828 T:18446744072530431864 INFO: msg: libdvdreadVDOpenFilePath:dvdinput_open smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.BUP failed
15:42:24.828 T:18446744072530431864 DEBUG: msg: libdvdread: Can't open file VIDEO_TS.IFO.
15:42:24.828 T:18446744072530431864 DEBUG: msg: libdvdnav: vm: failed to read VIDEO_TS.IFO
15:42:24.828 T:18446744072530431864 ERROR: Error on dvdnav_open
15:42:24.828 T:18446744072530431864 ERROR: CVideoPlayer::OpenInputStream - error opening [smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.IFO]
15:42:24.829 T:18446744072530431864 NOTICE: CVideoPlayer::OnExit()
15:42:24.829 T:18446744072530431864 DEBUG: OnPlayBackStopped: play state was 1, starting 1
15:42:24.829 T:18446744072511990544 DEBUG: OnPlayBackStopped: play state was 3, starting 0
15:42:24.829 T:18446744072530431864 DEBUG: Thread VideoPlayer 18446744072530431864 terminating
15:42:24.869 T:18446744072511990544 ERROR: Playlist Player: skipping unplayable item: 0, path [smb://192.168.1.253/Disk_a1/HomeMovies/Messico DVD (2001)/VIDEO_TS/VIDEO_TS.IFO]
And now I can't play it anymore. Kodi asks me if I want to delete it from the library, since this movie does not exist anymore.
I also don't understand why libdvdcss is triggered, since there is no needed decryption. Maybe tomorrow it will work again, who knows... It's a matter of trying and trying. I have 10 DVD which all had this issue. None of them would play, but yesterday and today they all play fine, and I haven't done anything.... Today I have added this Mexico video and it won't play.
This strange behavioiur only happens with IFO files - the rest always plays nice, 100% of the time.
Any suggestions on how I may be able to fix the problem?
Thanks and ciao.
Thanks and ciao.
