2019-04-03, 17:05
(2018-03-31, 21:55)bosz Wrote: [ -> ]Hello bosz,(2018-03-28, 22:28)kinggo Wrote: [ -> ] I'm pretty sure it already has a static one. Maybe you can't change it but that is something you don't need to do anyway.No, the IP was generated upon the order of loging onto the network. I managed to set a static IP on the NAS it self. Tried to switch to the FTP protocol to get things up and running. I was able to log into the NAS this way but unfortunately KODI refused to successfully download a movie from a source, but this in not important - I GOT IT(smb) TO WORK PROPERLY on my last attempt - literally i was about to quit the sh*t, and have a beer
Since i'm seeing i'm not the only one with this "issue" according to the entries in Google i wanna lay it out for everyone to see .
The solution to SMB shares not being visible on android devices is:
1) You need to enter your servers name (or IP, does not matter) by hand, as KINGGO mentioned in this thread
2)BE SURE TO ENTER THE LOCATION OF THE FOLDER YOU WANT TO ACCESS AS SHOWN BELOW - yes this is that simple ;]
I'm not aware of the rules and regulations of this board, but i'd mark this tread as solved, a pin it some place to others to learn from. It's up to the mods.
I'd like to thank Everyone that tried to help and wish all of You a happy easter.
The image under 2)BE SURE...AS SHOWN BELOW... is not accessible. Could you explain how you entered the folder location? I have tried SMB://xxx.xxx.xxx.xxx/Folder with no luck.
