2018-03-20, 17:43
2018-03-20, 18:36
The only way possible to get actors from sources that aren't already included in Ember, would be for you to manually add/edit them in. Nothing automatic outside of what scrapers are already there.
2018-03-20, 20:45
Would Ember allow me to add my own custom actor.jpg or .png so that it appears in the library info page of a title? Specifically when I select a title, select the info page, select extended info, and select a cast member picture, a new full size window opens with more pictures of the cast member that can be browsed one after the other. Will my custom additions appear there? Is there a manual method to insert these custom jpg/png's without using a 3rd party software? Is there another software preferred that can do this considering it is the only thing I require it do? TIA.
