Hi
Currently changing video track in a multi video mkv isn't available to map to a key requiring to have to change in video settings.
Audio track selection has a keymap be nice to have video track also.
Hi @
FernetMenta
Do you know if this feature is possible to implement with videoplayer?
And one side req if I may:
When a stream swap via the new action occurs, an info dialogue appears that projects the new stream's name (if any).
But, if the stream doesn't have name (which is the case on eg youtube or netflix videos) the info dialog just pops up with no info, just the head "Video stream".
Is it possible that if stream has no name, the stream's # (eg 1/3, 2/3, 3/3) is displayed instead?
That's not just cosmetic. For instance on youtube stream #s are progressing based on resolution, and on neftlix based on bitrate.
So knowing on what stream you are on, you can tell how high in the chain you are, regarding res or bitrate.
Wow guys you're on fire lately.
