2018-03-21, 14:56
I've got a Wetek and using a Harmony remote to power on and off the box + tv + amplifier.
To turn off the box, I need to do it from the menu but would like to send a command via infrared. Any idea (I don't have a lirc dongle)?
I also use a second screen that doesn't support more than 720p (tge usual definition is 1070p. I've got two hdmi outputs on the amplifier. To be able to display to the second screen, I need to modify the screen resolution via rhe menu (painful because sometimes the first screen is already in use by my wife). Any way to assign a command on the Jarmony remote to switch configuration ?
Thanks a lot 4 your help. Cheers.
