Full Version: IPTV Recorder
(2019-01-12, 18:03)maiers12 Wrote: [ -> ]
(2019-01-12, 17:05)primaeval Wrote: [ -> ]
(2019-01-12, 16:48)maiers12 Wrote: [ -> ]I'm tryng yo upload a scrrenshot of my browser but I don't understand how to do... I can tell you that near the reply button there is nothing...
I will try to finf ffmpeg version 4
 It might be one of the Kodi forum policies that don't enable some features until you have posted 10 links or been on here a certain amount of time.
Try asking the moderators to do it for you.
This is what I get now...
http://system01.dyndns.org:8000/maiers12/Xxxxx/598: Protocol not found
Did you mean file:http://system01.dyndns.org:8000/maiers12/Xxxx/598?
 This post on the Kodi forum has a link to your password in it.
https://forum.kodi.tv/showthread.php?tid...pid2807821
which links to
removed
f you don't want someone to steal your account either delete the link from the post with the Edit button or remove it from paste.kodi.tv.
If you can't then ask @DarrenHill to kindly do it for you.
Do not change it in your m3u file.
It looks like that is what you have done.
(2019-01-12, 18:34)primaeval Wrote: [ -> ]
(2019-01-12, 17:05)primaeval Wrote: [ -> ] It might be one of the Kodi forum policies that don't enable some features until you have posted 10 links or been on here a certain amount of time.
which links to
removed
if you don't want someone to steal your account either delete the link from the post with the Edit button or remove it from paste.kodi.tv.
Thank you, but I can’t also send messages to the administrator. Can you please do it for me.
The last lines are the end of the ffmpeg log file of version 0.84
I've removed the links. If any more need doing or anything is wrong just ping me.
(2019-01-12, 19:02)maiers12 Wrote: [ -> ]
(2019-01-12, 18:03)maiers12 Wrote: [ -> ]This is what I get now...
which links to
removed
 Try recording something on a desktop machine with ffmpeg version 4.
It might be your version 3 isn't new enough for your streams.
(2019-01-12, 19:14)DarrenHill Wrote: [ -> ]I've removed the links. If any more need doing or anything is wrong just ping me.
 Thanks very much.
Quote:You should be able to write to anywhere that Kodi has write permissions.
Use the Backspace or Back key to back out of the temp folder and you should get to the top of the Kodi folders tree.
Thank you very much. I chose an smb folder now. But first i tried a local folder. There was no problem to record a movie.
With the smb folder i can make a recording job. After the time i find a new subfolder with the name of the movie on the smb folder. So kodi can write there. But there is no movie file in it. Which entry is wrong in the settings?
Thank you Elluminatus
(2019-01-13, 01:26)Elluminatus Wrote: [ -> ]
Everything should be on the defaults except:
Kodi Recordings Folder = your smb share
ffmpeg exe = your ffmpeg location
Did you make a new recording after you changed the folder location?
Does it still reliably record to the default temp folder?
(2019-01-12, 19:15)primaeval Wrote: [ -> ]
(2019-01-12, 18:34)primaeval Wrote: [ -> ] This post on the Kodi forum has a link to your password in it.
which links to
removed
I set up a windows machine and everything works, any idea where to find a compiled version 4 of ffmpeg ?
Thank you again.
(2019-01-13, 10:09)primaeval Wrote: [ -> ]
Yes I made a new recording. When I look directly on the server in the folder, dann there is a json file, but I cannot see this file under recordings, there I only can see the folder of the serie.
Greetings Elluminatus
(2019-01-13, 16:05)Elluminatus Wrote: [ -> ]
(2019-01-13, 01:26)Elluminatus Wrote: [ -> ]Thank you very much. I chose an smb folder now. But first i tried a local folder. There was no problem to record a movie.
 Try 0.0.85.
It was using the wrong recording path. The ffmpeg recording path if you turn off the pipe setting.
@maiers12 see if this fixes your problem too.
I'm going to blame our new kittens for sitting on my keyboard all the time.
(2019-01-13, 16:43)primaeval Wrote: [ -> ]
(2019-01-13, 10:09)primaeval Wrote: [ -> ]Everything should be on the defaults except:
 Try 0.0.85.
Now it works, thank you very much for your effort. I didn’t understand very well yor last sentence about the kittens, but now take a rest from he keyboard.
Thank you again
(2019-01-13, 21:53)maiers12 Wrote: [ -> ]
(2019-01-13, 16:05)Elluminatus Wrote: [ -> ]Yes I made a new recording. When I look directly on the server in the folder, dann there is a json file, but I cannot see this file under recordings, there I only can see the folder of the serie.
 Try 0.0.85.
Thank you again
 Good.
We've got two new young kittens in our house and they have decided that the best place to sleep is on my desk, preferably on my keyboard, so I can tickle their tummies.
Would anyone know which version of ffmpeg matches best the amazon fire tv box? Cheers
(2019-01-16, 08:35)martybob Wrote: [ -> ]Would anyone know which version of ffmpeg matches best the amazon fire tv box? Cheers
I don't know exactly but this is my usual advice for Android. It might help.
Get "Droid Hardware Info" from the Play Store.
https://play.google.com/store/apps/detai...info&hl=en
Look for the CPU Architecure and Instruction Set on this page of the app.
https://lh3.googleusercontent.com/t7UNvC...w1920-h946
Download the Khang ffmpeg release that matches best.
https://github.com/Khang-NT/ffmpeg-binar...d/releases
You can also see hardware info at the top of the kodi.log file.
Thank you all sorted now great job!
