I changed it to 1/1 and added couple of more schedules. All were recored at the expected time.
One thing I've noticed, when you schedule them and then alter after/before it won't reflect it on already scheduled jobs. But I still have no idea why some of them were kicking late. I'll keep digging.
(2019-01-23, 17:05)dzejms Wrote: [ -> ]I changed it to 1/1 and added couple of more schedules. All were recored at the expected time.
Good.
The job files are made either as soon as you make the rule, or on a daily update, with all the settings at the time it is made.
It was done that way so you could use an external scheduler when Kodi wasn't running.
However I have only got around to making it work for the external Windows scheduler.
It also limits the recordings to simple http streams instead of addon streams.
Hi Primaeval, I have a little question. I’ve tried to record a live transmission but the plugin give an error. Here the log file if you want to investigate...
https://paste.kodi.tv/obonezawug.kodi
Thank you
(2019-01-27, 17:46)maiers12 Wrote: [ -> ]Hi Primaeval, I have a little question. I’ve tried to record a live transmission but the plugin give an error. Here the log file if you want to investigate...
Thank you
Try version 0.0.87.
It was getting confused with the two ' in the program title.
(2019-01-27, 18:20)primaeval Wrote: [ -> ] (2019-01-27, 17:46)maiers12 Wrote: [ -> ]Hi Primaeval, I have a little question. I’ve tried to record a live transmission but the plugin give an error. Here the log file if you want to investigate...
Thank you
Try version 0.0.87.
Seems to work thank you again
Hey guys,
First of all, thank you primaeval for this plugin, works beautifully.
I've just got one question to see if it's possible.
My IPTV provider doesn't provide correct EPG for Pay Per Views (Which most struggle with).
Is there a way to force record at a certain time on certain channels?
As when i go through Channel Groups > PPV events, nothing is listed, so I can't set anything to record.
Apologies if this has been requested or a fix has been mention for this previously.
Any feedback would be great.
Thanks again primaeval for the plugin.
Does your IPTV provider have catchup of events?
Unfortunately not, not that i'm aware, it's a budget IPTV so I can't complain.
(2019-01-27, 22:58)Nath_Explosion Wrote: [ -> ]Hey guys,
If you only get a playable stream for your channel in your m3u playlist just before an event, I don't think you will be able to record it reliably.
You can do a timed record on a channel. It is in the channel context menu.
But if there is no stream in the m3u the channel won't show up.
If you just want to record the event for posterity you can try to force a "Maintenance \ Reload Data" close to the event if you are at home.
Thanks for the reply primaeval, I'm unable to set up a timed record due to any channels not showing under the PPV group as you mentioned.
How would I go about carrying out a force maintenance / reload data?
(2019-01-28, 13:55)Nath_Explosion Wrote: [ -> ]Thanks for the reply primaeval, I'm unable to set up a timed record due to any channels not showing under the PPV group as you mentioned.
Turn on "Settings \ Debug \ Debugging Menu Items".
If you know how soon before an event you get a stream in your m3u, you could set the Service time to then.
Alternatively if your event ends up in some sort of tv catchup list you could use my "Addon Recorder" addon.
Cheers primaeval, i'll give your suggestions a go.
Hi, Primaeval.
I had to change the EPG provider and now even I can see the data in the Iptv plugin, the same chanels in your plugin are empty.
https://paste.kodi.tv/anoseqovad.kodi
Here the log file. If you can investigte thank you very much as usual.
Bye
P.S.
How are your new kiitens ?
(2019-02-05, 13:56)maiers12 Wrote: [ -> ]Hi, Primaeval.
Bye
P.S.
Hi. There is nothing in the log.
Did you do a NUKE when you changed providers?
It might help clear things out. The channel ids will most likely have changed.
Enable it in Debug Menus in settings.
The kittens have been enjoying their first snow. They come back inside soaking wet and use my shirt to dry off.
(2019-02-05, 14:19)primaeval Wrote: [ -> ] (2019-02-05, 13:56)maiers12 Wrote: [ -> ]Hi, Primaeval.
Bye
P.S.
Tried but nothing has changed.
You kittens are very smart...
