(2019-03-05, 00:29)CpTHOOK Wrote: [ -> ]Hello forum.. great add-on!! I have it working just fine in Win10 but I cannot seem to get it working with Linux-Mint. I suspect the FFmpeg file that i'm selecting in settings is incorrect. The .json and .ts files show in the selected share when a recording begins, however the .ts does not increase in size. I have Kodi 18.1 and ffmpeg v7:2.8.15-0ubuntu0.16.04.1 installed on a VM. I've tried pointing the "ffmpeg exe" to the following locations below w/o success. My most recent log is attached. Please advise if possible, thanks!!
MyLog/usr/bin/ffmpeg;
/usr/share/ffmpeg; and
/usr/share/man/man1/ffmpeg.1.gz
According to this post Linux Mint uses avconv instead of ffmpeg. avconv is a fork of ffmpeg with more codecs.
https://forums.linuxmint.com/viewtopic.php?t=239749
I suspect it is in /usr/bin/avconv but you'll have to check yourself.
(2019-03-05, 09:28)primaeval Wrote: [ -> ] (2019-03-04, 23:25)Laser78 Wrote: [ -> ]Hi,
In Windows 10 everything works ok but Android does not and I use the same list, I do not understand ... I have modified the list leaving only 1 channel and I also get error.
It can't uncompress your xml file after downloading it to a temporary file.
Change the name of
"userdata\addon_data\plugin.video.iptv.recorder\xmltv1.tmp"
to
"userdata\addon_data\plugin.video.iptv.recorder\xmltv1.gz"
and see if you can open it with a program like 7zip.
Check if the source of your xml is ok by opening its url in a browser.
it is a remote URL, I have changed the extension and recreates the temporary one. TMP
(2019-03-05, 10:10)primaeval Wrote: [ -> ] (2019-03-05, 10:04)Laser78 Wrote: [ -> ]
Now you need to open it up and see if it contains your xml file or if it is corrupt.
Use a program like 7zip.
https://www.7-zip.org/
or on android any one of these will probably work
https://play.google.com/store/search?q=gzip&c=apps
it contains the list of channels, it is the same one that I use in Windows 10 and it works for me, but not Android.
I'm going to investigate because now, in Android, no list works for me, in all of them I see an error. I'm going to uninstall the addon and start over
(2019-03-05, 09:33)primaeval Wrote: [ -> ] (2019-03-05, 00:29)CpTHOOK Wrote: [ -> ]
Thanks for the tip!! So I installed libav-tools and avconv was indeed in the location you referenced. However-- same results. I'm also suspecting that my issues may have to do with not passing a physical graphics card through to my VM. I'm using VNC, however, forgive me if this seems way off-base. My log attached. I already had this VM going for awhile and using it to update my Kodi library w/ MariaDB. It would be sooooo perfect if I could add this PVR to it. If not... I'll have to give in to Win10.
MyLog
(2019-03-06, 05:24)CpTHOOK Wrote: [ -> ] (2019-03-05, 09:33)primaeval Wrote: [ -> ] (2019-03-05, 00:29)CpTHOOK Wrote: [ -> ]
MyLog
There are a couple of things you could try.
See if turning off the "ffmpeg reconnect arguments" helps.
Someone had a problem with them on their version of ffmpeg so I made them optional.
Turn on ffmpeg debugging in
Settings \ Debug \ Debug ffmpeg stdout/stderr
The output and error streams should then end up in the jobs folder.
userdata\addon_data\plugin.video.iptv.recorder\jobs
They should show you if avconv/ffmpeg even started and possible errors.
You could also try to install the official version of ffmpeg.
You might have to build it from source.
http://ffmpeg.org/download.html#build-linux
(2019-03-06, 00:37)Laser78 Wrote: [ -> ] (2019-03-05, 10:10)primaeval Wrote: [ -> ] (2019-03-05, 10:04)Laser78 Wrote: [ -> ]
You might need to delete the data directory manually if something has got stuck in there.
Since latest update I'm getting (can't load any groups):
Quote:2019-03-06 10:41:13.565 T:123145441353728 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'utf8' codec can't decode byte 0x82 in position 2949075: invalid start byte
File "/Users/tbrek/Library/Application Support/Kodi/addons/plugin.video.iptv.recorder/main.py", line 3151, in <module>
plugin.run()
File "/Users/tbrek/Library/Application Support/Kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 332, in run
items = self._dispatch(self.request.path)
File "/Users/tbrek/Library/Application Support/Kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 306, in _dispatch
listitems = view_func(**items)
File "/Users/tbrek/Library/Application Support/Kodi/addons/plugin.video.iptv.recorder/main.py", line 2217, in full_service
xmltv()
File "/Users/tbrek/Library/Application Support/Kodi/addons/plugin.video.iptv.recorder/main.py", line 2605, in xmltv
data = data.decode(encoding)
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.13_x86_64-target-release/lib/python2.7/encodings/utf_8.py", line 16, in decode
UnicodeDecodeError: 'utf8' codec can't decode byte 0x82 in position 2949075: invalid start byte
(2019-03-06, 12:42)dzejms Wrote: [ -> ]Since latest update I'm getting (can't load any groups):
plugin.run()
xmltv()
It can't decode your xmltv file.
There is a bad utf8 character at position 2949075 in the file.
Does the encoding at the top of the file match the contents of the file.
xml:
<?xml version="1.0" encoding="UTF-8"?>
Is there a chinese character that should have been encoded as utf16 or is the file actually in ISO-8859-1?
Notepad++ might help you uncover the true encoding.
Oh. Could be epg issue itself:
https://epg.ovh/pl.xml
Quote:This page contains the following errors:
error on line 20131 at column 19: Specification mandates value for attribute late error on line 20131 at column 20: Encoding error
Below is a rendering of the page up to the first error.
(2019-03-06, 13:05)dzejms Wrote: [ -> ]Oh. Could be epg issue itself: https://epg.ovh/pl.xml
The xml is a mess.You'll have to get them to try and fix it.
You can also use an online xml validator like
https://codebeautify.org/xmlvalidator
That one finds this nonsense:
Looks like the gz version is loading with no issues. Thanks for your help.
(2019-03-06, 13:56)dzejms Wrote: [ -> ]Looks like the gz version is loading with no issues. Thanks for your help.
There is still something wrong with the gz version although it loads ok in IPTV Recorder.
It won't load in TV Guide Fullscreen which needs completely correct xml.
Could you let them know on their forum.
(2019-03-06, 09:20)primaeval Wrote: [ -> ] (2019-03-06, 05:24)CpTHOOK Wrote: [ -> ] (2019-03-05, 09:33)primaeval Wrote: [ -> ]
Turning off reconnect arguments gave me the same results. I turned on ffmpeg debugging prior to, per your recommendations. Log below. I'll have to read up on building a version of this from the source, any tips or guidance posts out there that you recommend? The version listed in the LM software manager has the same link you provided.
DbugLog
(2019-03-07, 05:35)CpTHOOK Wrote: [ -> ] (2019-03-06, 09:20)primaeval Wrote: [ -> ] (2019-03-06, 05:24)CpTHOOK Wrote: [ -> ]
DbugLog
The version of ffmpeg in the log is much too old.
It can't handle the "ffmpeg reconnect arguments". reconnect_at_eof is one of them:
Unrecognized option 'reconnect_at_eof'.
So you should turn them off or update ffmpeg.
I found this about compiling for Mint:
https://trac.ffmpeg.org/wiki/CompilationGuide/Ubuntu
