(2019-03-17, 12:11)encol Wrote: [ -> ]Hi, i get this syntax error:
xml:
23:32:09 T:1611537112 ERROR: [plugin.video.iptv.recorder] service started...
23:32:10 T:1674597664 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.SyntaxError'>
Error Contents: ('invalid syntax', ('/storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/addons/plugin.video.iptv.recorder/main.py', 1804, 25, ' streams = {x[3]:x for x in streams}\n'))
SyntaxError: ('invalid syntax', ('/storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/addons/plugin.video.iptv.recorder/main.py', 1804, 25, ' streams = {x[3]:x for x in streams}\n'))
That looks like it won't work on Kodi 16 Jarvis which is what SPMC is based on.
Try using official Kodi 18.
I don't really want to try and back-port this to Jarvis. Kodi 19 is going to cause enough problems when it switches to python 3.
(2019-03-17, 12:18)primaeval Wrote: [ -> ] That looks like it won't work on Kodi 16 Jarvis which is what SPMC is based on.
Unfortunately, my device run on android 4.4.
I don't think Kodi 19 can run on it
(2019-03-17, 12:24)encol Wrote: [ -> ] (2019-03-17, 12:18)primaeval Wrote: [ -> ] That looks like it won't work on Kodi 16 Jarvis which is what SPMC is based on.
You can fix the problem in the log with this change:
https://github.com/primaeval/plugin.vide...edf1cae9c7
However, I fixed that and a problem in xbmcswift for Kodi 16 Jarvis on Windows but recording locked up,
so I'm not going to try and fix it myself.
I very much doubt an old device running android 4.4 would be able to cope with recording either.
Thanks a lot,
i'll try and report!
(2019-03-17, 13:24)encol Wrote: [ -> ]now i have this:
https://paste.kodi.tv/ifucogumuj.kodi
It's the same type of problem. There are probably loads more.
I really haven't got the energy to fix it.
Nobody is working on SPMC any more.
http://spmc.semperpax.com/
See if you can put LibreELEC on your Android box.
I did that on a couple of my old devices.
(2019-03-17, 15:29)encol Wrote: [ -> ]Smart-tech LE4048SA
I can’t find any specs on it. If it is an Amlogic chip then you might have luck.
If not time to buy a new one.
(2019-03-17, 16:42)ed_davidson01 Wrote: [ -> ]I can’t find any specs on it. If it is an Amlogic chip then you might have luck.
It is sold under different names, you can find some specs
here
Anyway, processor is an ARM Cortex-A7.
I succesfully rooted it and installed play store
(2019-03-17, 17:17)primaeval Wrote: [ -> ] I've fixed the other dict comprehensions but I haven't got anything to test it on.
https://github.com/primaeval/plugin.vide.../tree/spmc
If there are more problems open an issue on github and we'll discuss the details there.
Thanks a lot, now channel search works fine, but i have another error.
Unfortunately, now i have some problem in creating an account on github, so (for now) i cannot open an issue.
However, i pasted the error here:
sedemotece.kodi (paste)
(2019-03-17, 18:56)encol Wrote: [ -> ] (2019-03-17, 16:42)ed_davidson01 Wrote: [ -> ]I can’t find any specs on it. If it is an Amlogic chip then you might have luck.
It is sold under different names, you can find some specs here
However, i pasted the error here: sedemotece.kodi (paste)
That error is because I made a version of xbmcswift to show poster images properly.
Delete the one in
addons\script.module.xbmcswift2
and either re-install IPTV Recorder or another of my addons that uses it and it should now pull in the version from the Kodi repo.
Or you can grab the zip from here
https://mirrors.kodi.tv/addons/jarvis/sc...-2.4.0.zip
The difference is here if you want to modify the installed version. Just remove these lines.
https://github.com/primaeval/script.modu...d88fe44ebe
