(2019-03-17, 23:55)encol Wrote: [ -> ]Ok, another little step: now hour input pops up, but recording doesn't start: https://paste.kodi.tv/kenejudome.kodi
That probably affected the main branch too.
All the spmc changes including the sane_name fix are now in version 0.0.121.
(2019-03-18, 12:12)encol Wrote: [ -> ]That's sad.
We were so close!
The only clue that might help is that some of the bug reports were due to running out of memory or storage space.
https://bugs.launchpad.net/bzr/+bug/723234
Make sure wherever you are recording to has enough space and is writeable by kodi.
(2019-03-17, 18:56)encol Wrote: [ -> ] (2019-03-17, 16:42)ed_davidson01 Wrote: [ -> ]I can’t find any specs on it. If it is an Amlogic chip then you might have luck.
If not time to buy a new one.
It is sold under different names, you can find some specs here
Anyway, processor is an ARM Cortex-A7.
I succesfully rooted it and installed play store
(2019-03-17, 17:17)primaeval Wrote: [ -> ] I've fixed the other dict comprehensions but I haven't got anything to test it on.
https://github.com/primaeval/plugin.vide.../tree/spmc
If there are more problems open an issue on github and we'll discuss the details there.
Thanks a lot, now channel search works fine, but i have another error.
Unfortunately, now i have some problem in creating an account on github, so (for now) i cannot open an issue.
However, i pasted the error here: sedemotece.kodi (paste)
I can’t open the link to the box.
Looks like it’s an android tv. Not a box at all.
(2019-03-18, 15:35)ed_davidson01 Wrote: [ -> ]Looks like it’s an android tv. Not a box at all.
Yes, it is.
(2019-03-18, 12:26)primaeval Wrote: [ -> ] (2019-03-18, 12:12)encol Wrote: [ -> ]That's sad.
We were so close!
I checked this. I have 3.7GB free in the recording location and it's writeable: in the recording folder was created a folder "Other", and inside it a folder with the channel name.
Inside that folder, two files:
- .json (79 bytes)
- .ts (0 bytes)
the error is raised by the instruction:
data = p.stdout.read(1000000)
in a file
/storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/userdata/addon_data/plugin.video.iptv.recorder/jobs/af5044c7-4793-11e9-ae1f-bb7a85059de8.py
