(2019-04-20, 08:20)primaeval Wrote: [ -> ] (2019-04-19, 22:05)kaner007 Wrote: [ -> ]Great thanks so much for all of your support. I'm almost there. If I want to record something the following message appears: ITPV Recorder not found. Any idea what is wrong?
You'll have to give me more clues.
What was not found?
What exactly were you trying to do?
Have you set up IPTV Simple Client correctly so that it shows programs and plays channels? -> YES. I can see a lot of channels and swtich between the channels
Have you restarted Kodi? -> YES several times
Is
IPTV Recorder \ Channel Groups \ All Channels
full of the same channels and programs as
Kodi \ TV \ Guide? -> Yes the same channels are visible in IPTV Recorder and ITPV Simple Client
Can you play the channels in IPTV Recorder? -> Yes
Can you record in IPTV Recorder? -> partially working I can add "Add on time Rule" and record forexample 5 minutes this works perfectly.
If I'm in ITPV Simple Client and want to "Schedule ITPV Recorder" on a channel an error comes up ITPV Recorder not found.
The error log looks like: I marked the errors in amber which I think are the relevant once from the action done...
2019-04-20 08:50:59.455 T:123145373655040 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
2019-04-20 08:51:01.076 T:123145375264768 WARNING: Previous line repeats 187 times.
2019-04-20 08:51:01.076 T:123145375264768 NOTICE: [xbmcswift2] Request for "/channel/Arte.de/Arte+FHD+DE" matches rule for function "channel"
2019-04-20 08:51:01.087 T:123145375264768 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
2019-04-20 08:51:02.831 T:123145375801344 WARNING: Previous line repeats 5 times.
2019-04-20 08:51:02.831 T:123145375801344 NOTICE: [xbmcswift2] Request for "/group/LIVE%3A+Germany" matches rule for function "group"
2019-04-20 08:51:02.832 T:123145375801344 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
2019-04-20 08:51:02.951 T:123145375801344 WARNING: Previous line repeats 69 times.
2019-04-20 08:51:02.951 T:123145375801344 ERROR: /Users/USER/Library/Application Support/Kodi/addons/plugin.video.iptv.recorder/main.py:2330: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
if channelname not in favourites and channelid:
2019-04-20 08:51:02.952 T:123145375801344 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
2019-04-20 08:52:03.908 T:123145377947648 WARNING: Previous line repeats 186 times.
2019-04-20 08:52:03.908 T:123145377947648 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std:
tring &): Opening default device Built-in Output
2019-04-20 08:53:05.153 T:123145374191616 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
2019-04-20 08:53:22.934 T:123145373655040 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'locale.Error'>
Error Contents: unsupported locale setting
File "/Users/USER/Library/Application Support/Kodi/addons/plugin.video.iptv.recorder/contextEPG.py", line 44, in <module>
locale.setlocale(locale.LC_TIME, language)
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.13_x86_64-target-release/lib/python2.7/locale.py", line 581, in setlocale
Error: unsupported locale setting
2019-04-20 08:53:22.940 T:123145377947648 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std:tring &): Opening default device Built-in Output
2019-04-20 08:54:28.637 T:123145374728192 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
