(2020-04-26, 15:08)Jezze Wrote: [ -> ]So this not working with libreelec?
Its working with libreelec. I am currently using it with no problem on my rpi 4 and the ffmpeg from the libreelec repo
(2020-04-27, 00:33)samueljones Wrote: [ -> ] (2020-04-26, 15:08)Jezze Wrote: [ -> ]So this not working with libreelec?
What is ffmpeg path for libreelec iptv recorder setting? My raspberry got stuck at iptv recorder finding streams message.
(2020-04-27, 11:37)Jezze Wrote: [ -> ] (2020-04-27, 00:33)samueljones Wrote: [ -> ] (2020-04-26, 15:08)Jezze Wrote: [ -> ]So this not working with libreelec?
Install the ffmpeg from the Repo and the path is : storage/.kodi/addons/tools.ffmpeg-tools/bin/ffmpeg
I have rpi4, latest official libreelec, ffmpeg-tools installed but i get error with iptv recorder. Here is lines from debug:
https://pastebin.com/hvzQ83Aq
Can someone help to solve this?
Can someone help with Ffmpeg? I want to configure IPTV Recorder on Android TV device.
Which Ffmpeg to download, how to install it/where to place it?
Hi!
I am trying this great addon on two pc, but no luck so far. When it starts to record, after 1 second it say "Recording finished". What am I doing wrong?
Win10, Kodi 18.6, Ffmpeg installed on desktop and linked, I tried on Estuary and Xonfluence skin. I tried with only IPTV PVR Simple Client and IPTV Recorder installed.
This is how my m3u file looks like:
#EXTM3U tvg-shift=2
#EXTINF:-1 group-title="Slovenski" tvg-id="1000259" tvg-name="1000259" tvg-logo="SLO_1.png",[COLOR gold]SLO 1[/COLOR]
https://tv.si/ts/Slo1/stream_multi.m3u8|User-Agent="AppleCoreMedia/1.0.0.8C148 (iPad; U; CPU OS 4_2_1 like Mac OS X; en_us)"
RECORD ONCE - starts recording and immediately stops it.
REMIND ONCE - works fine.
WATCH ONCE - stops other stream, but does not and play the channel.
PLAY CHANNEL - works fine.
I tried NUKE, reset ...
I will appreciate any help. Thanks!
UPDATE:
Here is my logfile:
http://paste.kodi.tv/rekifanufo
People, is there a tutorial for installing and configuring IPTV Recorder?
I stuck on Ffmpeg step, I have no idea what to download and where to place it.
It's Android TV 9.0 device.
Thanks to primaeval for this fantastic add-on.
I'm using it in Windows with no problem at all and works fine.
But, when I try using it in CoreELEC (in 2 TV-Box devices - both x96 Max+ -):
a) I have installed the last version of IPTV Recorder add-on.
b) I have downloaded ffmpeg-toos addon from CoreELEC repository.
c) I have edited "ffmpeg exe" in:
Userdata\addon_data\plugin.video.iptv.recorder\settings.xml
<setting id="ffmpeg">/storage/.kodi/addons/tools.ffmpeg-tools/bin/ffmpeg</setting>
d) I use /storage/downloads as destination folder
OK... it seems it should work when I make a new: Add Timed Recording" (the same thing I do in Windows version, with same channel list and same epg source)... well... the add-on does NOT show any error message at all, but never creates the recording file.
Any idea about what the problem could be?
Kind regards
SOLVED.
It was not a problem with the addon. The problem was that I had not installed "PVR IPTV Simple Client" in CoreELEC (as I thought); I had installed "PVR IPTV Archive Client".
Now I have deleted "PVR IPTV Archive Client" and installed "PVR IPTV Simple Client" and IPTV Recorder is working fine.4
Kind regards
Does anyone knows whats the setting to watch one and record another TV channel at the same time? I am using kodi on firestick. Tnx!
(2020-02-06, 02:40)thestupidbloke Wrote: [ -> ]struggled with this for ages... looked all over the net and tried to learn some stuff about LOCALE etc. Got no where. For some reason did an addon search in kodi for "locale" and found a "locale" addon in the LibreElec repository. Prompted me to restart and so glad to say this has fixed the issue for me.
I am on LibreElec, hope you have the same success with CoreElec!
Cheers from CoreELEC user...
I too kept getting an Error trying to Schedule a Recording from the EPG.
As you said install - LOCALE - Addon and Reboot when prompted fixed the problem.
Hello there
I`m getting the error "error parsing date".
I figured its because of the locality of the m3u file but can't figure out how to tell the recorder which one the right one is.
I tried adding language = "de_ch.ISO8859-15" in buuuut I'm pretty sure I'm just breaking the code.
Any suggestions?
Thanks a lot!
When I set a weekly rule from full EPG, in the rule section the rule is always 1 hrs too early.
Also the rule never kicks off a recording.
When I set a single recording job and check in the jobs section of IPTV recorder, the time incorrect and the recording happens.
Why are my rules 1 hour off and don't start?
Thanks for the help
