(2021-01-20, 14:58)mpetit480 Wrote: [ -> ]Hi
ts file have a size of 0.
Could you help me to make work IPTV Recorder ?
in Kodi 18.9 , kodi.log
2021-01-20 13:31:45.045 T:2880512880 ERROR: /storage/.kodi/addons/plugin.video.iptv.recorder/main.py:2330: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
if channelname not in favourites and channelid:
2021-01-20 13:32:18.803 T:2451616624 ERROR: GetDirectory - Error getting plugin://plugin.video.iptv.recorder/record_once/7709/C111.api.telerama.fr/Arte
2021-01-20 13:32:22.097 T:2451616624 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'read'
File "/storage/.kodi/userdata/addon_data/plugin.video.iptv.recorder/jobs/8926de54-5b1b-11eb-ab61-dca6329255ad.py", line 28, in <module>
data = p.stdout.read(1000000)
AttributeError: 'NoneType' object has no attribute 'read'
2021-01-20 13:41:57.443 T:2498745200 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'locale.Error'>
Error Contents: unsupported locale setting
File "/storage/.kodi/addons/plugin.video.iptv.recorder/contextEPG.py", line 54, in <module>
usedLocale = locale.setlocale(locale.LC_TIME, "")
File "/usr/lib/python2.7/locale.py", line 581, in setlocale
Error: unsupported locale setting
I created this modified version with encoding and locale fix. You only need to replace the polish weekdays and months with french (see how the month endings is differrent in polish language) in contextEPG.py.
If the weekdays and months are correct you only need to hashtag lookup_table date:
python:
#date = lookup_table(date)
plugin.video.iptv.recorder.zip
https://drive.google.com/file/d/1-7nF6WPH9KluKGOZQZozEaH-dK7n24Kt/view?usp=sharing
python:
def lookup_table(s):
lookup_table = {
"Stycznia": "Styczeń", "Lutego": "Luty",
"Marca": "Marzec", "Kwietnia": "Kwiecień",
"Maja": "Maj", "Czerwca": "Czerwiec",
"Lipca": "Lipiec", "Sierpnia": "Sierpień",
"Wrze\xc5\x9bnia": "Wrzesień", "Pa\xc5\xbadziernika": "Październik",
"Listopada": "Listopad", "Grudnia": "Grudzień",
"Poniedzia\xc5\x82ek" : "Poniedziałek", "Wtorek" : "Wtorek",
"\xc5\x9aroda": "Środa", "Czwartek" : "Czwartek",
"Pi\xc4\x85tek" : "Piątek", "Sobota" : "Sobota",
"Niedziela" : "Niedziela",
for k, v in lookup_table.items():
s = s.replace(k, v)
return s
It's also possible that your system is missing locale then you need to install them manually.
https://discourse.osmc.tv/t/locale-error/89141
On OSMC:
xml:
export LC_ALL="pl_PL.UTF-8"
export LC_CTYPE="pl_PL.UTF-8"
sudo dpkg-reconfigure locales
Hi there,
I get following error when trying to record (e.g. via pvr simple iptv client channels list):
Quote:2021-04-15 10:52:12.506 T:16172 INFO <general>: initializing python engine.
2021-04-15 10:52:12.814 T:16172 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'AttributeError'>
Error Contents: 'str' object has no attribute 'decode'
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.iptv.recorder/context.py", line 13, in <module>
channel = channel.decode("utf8")
AttributeError: 'str' object has no attribute 'decode'
2021-04-15 10:52:12.932 T:16172 INFO <general>: Python interpreter stopped
2021-04-15 10:56:15.307 T:14283 INFO <general>: CWinSystemAndroid:
estroyWindow
my setup is:
- chromecast with google tv (must be armv7-a architecture; at least droid hardware info says so)
- kodi 19 (matrix)
- installed pvr simple iptv client
- installed iptv recorder plugin for kodi matrix
- pointed to armv7-a-full ffmpeg (extracted -> not the one with .tar.bz2 extension) in iptv recorder settings
- set recording folder to internal storage of chromecast in iptv recorder settings
My guess is that there is still something wrong with the ffmpeg integration (btw i cannot find tools.ffmpeg-tools folder under /storage/.kodi/addons/)...
can anyone help? thanks in advance
(2021-04-15, 11:22)jjojjo Wrote: [ -> ]Hi there,
estroyWindow
my setup is:
- kodi 19 (matrix)
A string can't be decoded, the problem is that this addon is not compatible with python 3 (Kodi v19). It needs to be translated. Translating it is not that hard, but it's a lot of work to do.
(2021-04-15, 16:52)Publish3r Wrote: [ -> ]A translated version for Matrix you can find here: https://github.com/Publish3r/repository....v.recorder
It's working good, but there are still some issues. I don't know, if i can fix the few issues.
You can give it a try.
thanks a lot for your help!! Unfortunately it wasn't succesful so far. I'm getting a bit further and i'm able to hit "record and play" now but then I get following error:
Quote:16 12:18:29.353 T:11692 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'xbmcswift2.urls.NotFoundException'>
Error Contents: No matching view found for /record_and_play/DE%3A+Das+Erste+HD
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.iptv.recorder/main.py", line 3433, in <module>
plugin.run()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 338, in run
items = self._dispatch(self.request.path)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 324, in _dispatch
raise NotFoundException('No matching view found for %s' % path)
xbmcswift2.urls.NotFoundException: No matching view found for /record_and_play/DE%3A+Das+Erste+HD
2021-04-16 12:18:29.639 T:11692 INFO <general>: Python interpreter stopped
2021-04-16 12:18:29.646 T:11691 ERROR <general>: GetDirectory - Error getting plugin://plugin.video.iptv.recorder/record_and_play/DE%3A+Das+Erste+HD
2021-04-16 12:18:29.655 T:10888 ERROR <general>: CGUIMediaWindow::GetDirectory(plugin://plugin.video.iptv.recorder/record_and_play/DE%3A+Das+Erste+HD) failed
2021-04-16 12:18:35.195 T:10860 INFO <general>: CAndroidUtils: Current resolution: 1920x1080 1920x1080 @ 59.940060 - Full Screen
2021-04-16 12:18:35.390 T:10888 INFO <general>: CWinSystemAndroid:
estroyWindow
2021-04-16 12:18:37.770 T:10860 INFO <general>: Got device sleep intent
2021-04-16 12:18:38.094 T:10888 INFO <general>: OnSleep: Running sleep jobs
2021-04-16 12:18:38.096 T:10888 INFO <general>: PumpPowerEvents: OnSleep called
Maybe some kind of incompatibility with the m3u?
greetings and once again: thank you very much :-)
Really happy to use every Day kodi and find many function i appreciate.
I actually use kodi 18.8 on my nvidia shield tv with catchup tv and more and iptv manager, work really fine and it's à real pleasure.
Now i will try to record some program with iptv recorder, after some problem with ffmpeg i was able to find the Good android version and my epg show fine in iptv recorder.
Try to put my record on a network attached storage and seems the config work well.
But.....
When i try to record a programm in iptv recorder screen, this one begins, create the folder for this programm, a json file and a ts file but the ts file was empty.
When i want to record something, i have a notification for the begining of the record and just after a notification for the end of the record, but like i said before only have create thé file but do not record anything.....
Where can be the issue ?
(2021-04-27, 16:38)MrPatate Wrote: [ -> ]Really happy to use every Day kodi and find many function i appreciate.
But.....
I'm having the same problem on Kodi 19.
I used the plugin.video.iptv.recorder-1.0.zip file from here:
I used the prebuilt-binaries armeabi-v7a ffmpeg file from here:
https://github.com/WritingMinds/ffmpeg-a...tag/v0.3.4
I created a folder for IPTV recordings on my USB hard drive that is attached to my Shield TV and used for OTA recordings.
Did I use the right files for my Shield TV?
(2021-05-04, 02:56)RKCRLR Wrote: [ -> ] (2021-04-27, 16:38)MrPatate Wrote: [ -> ]Really happy to use every Day kodi and find many function i appreciate.
But.....
I found this which discusses a similar problem:
https://github.com/primaeval/plugin.vide.../issues/27
I tried this file but the problem didn't change:
https://github.com/Khang-NT/ffmpeg-binar...ll.tar.bz2
(2021-05-04, 19:51)RKCRLR Wrote: [ -> ] (2021-05-04, 02:56)RKCRLR Wrote: [ -> ] (2021-04-27, 16:38)MrPatate Wrote: [ -> ]Really happy to use every Day kodi and find many function i appreciate.
But.....
I moved the ffmpeg (the arm64-v8a version) file to my Documents folder on my Shield TV. I've had other issues wit access permissions on the Shield.
It now will start recording however the recordings stop before the show is over. This may be because I'm recording from Locast but I haven't donated yet (I still have another problem to solve before I commit).
Also, Pluto.TV just won't record. Should I expect to be able to record Pluto.TV?
But.....
I use an IPTV Recorder 0.0.131 version (for a kodi 18 from primaeval's repo!?!) and my ffmpeg version seems to be well recognised. My record start well (no ffmpeg issue notification or something els) but end soon and give me a 0ko file.
Can I try to use Publish3r version (for Matrix) on a Kodi Leia?
Thanks Work on Octagon sx88 4k KODi 18.9
Thanks !
(2021-07-01, 13:28)Bua12120 Wrote: [ -> ]Thanks Work on Octagon sx88 4k KODi 18.9
Thanks !
What version of the addon did you install? Did you make any specific change?
helllo i am new here
how to Point to the ffmpeg exe in Settings in windows 10?thx
(2020-05-07, 10:33)kibtu Wrote: [ -> ]Hi!
I am trying this great addon on two pc, but no luck so far. When it starts to record, after 1 second it say "Recording finished". What am I doing wrong?
Win10, Kodi 18.6, Ffmpeg installed on desktop and linked, I tried on Estuary and Xonfluence skin. I tried with only IPTV PVR Simple Client and IPTV Recorder installed.
This is how my m3u file looks like:
#EXTM3U tvg-shift=2
#EXTINF:-1 group-title="Slovenski" tvg-id="1000259" tvg-name="1000259" tvg-logo="SLO_1.png",[COLOR gold]SLO 1[/COLOR]
https://tv.si/ts/Slo1/stream_multi.m3u8|User-Agent="AppleCoreMedia/1.0.0.8C148 (iPad; U; CPU OS 4_2_1 like Mac OS X; en_us)"
RECORD ONCE - starts recording and immediately stops it.
REMIND ONCE - works fine.
WATCH ONCE - stops other stream, but does not and play the channel.
PLAY CHANNEL - works fine.
I tried NUKE, reset ...
I will appreciate any help. Thanks!
UPDATE:
Here is my logfile: http://paste.kodi.tv/rekifanufo
I have the same problem .
On Android systems it works perfectly for me,
on Windows 10 it doesn't ...
