Full Version: Memorize audio level
hello.
i've the following suggestions, about the audio level defined
in osd :
a) memorize the audio level defined in osd, even when you
open another file. it's a little annoying to always have to
reduce the level, because it was at the maximum level by
default, and each time you open a file, it goes back to max.
so, my suggestion is to memorize the audio level, like xbmp
does.
b) if you can't/wan't do it, another interesting alternative
in this case may be to not put the default audio level to max,
but to medium. in this case, when you go to osd, you can
up or down the level. actually, yo can only down (the
first time you go to osd).
