(2018-03-24, 05:36)braz Wrote: [ -> ]Any of the compilation albums that have a musicbrainz id are put in an Everyone artist.
OK Here's my guess: Since "Everyone" is showing up on MB-scraped albums, I suspect at one point you got the song tags from musicbrainz. The artist id for "Various Artists" is 89ad4ac3-39f7-470e-963a-56509c546377 and when that is in the MB album artist ID tag, it will be used as the way to match an existing artist in the database (
if you also have an album MBID in the tags for that song). When "prefer online info" setting is off, the artist name string is whatever is in the artist entry in the database. Maybe sometime in the past you had a bad tag that had "everyone" as the artist name string when you scanned and Kodi first got that 89ad MBID. So you get it whenever your tags have the MBID. That happens even if you "fixed" the tag at some point and rescanned.
When you don't have an album artist MBID in your tags, Kodi matches artists using the artist name string, so finds "Various Artists" in the database and all is well.
Unfortunately, I don't know any good way to fix a bad MBID / artist name string pair in the database. You might be able to import an xml or nfo file with a dummy MBID for "Everyone" but I don't have much hope that will work, because of exisitng album artist links in the database.
You might get away with editing the database outside of Kodi. Find "Eveyone" in the artist table and delete the MBID for it. Find "Various Artists" and add the correct MBID 89ad4ac3-39f7-470e-963a-56509c546377. Then rescan all files with various artists and I think that should remove all song and album links to "Everyone", after which a "clean" should remove "Everyone" from the database.
At least if you can open your database in a db reader and look at the artist table to see if I am right about the MBID.
The only 100% reliable method I know without playing around in the database is
1. Move all song files that mention Various Artists or Everyone in tags out of your source
2. Update / clean the database. This will remove the artist entries for "Everyone" and "Various Artists"
3. In a tagging app, ensure all songs with "Various Artists" have the correct Album Artist or Artist MBID entry as appropriate. Note that Album Artist ID tag only gets used if Album ID tag is also present. Blank/null is also OK but having the MBID is better. Also ensure you don't have any rogue "Everyone" tags (I'm sure you already did this).
4. Move your song files back into your source and rescan.
5. If you have local artist nfo files ensure artist.nfo for Various Aritsts has the correct MBID in it. Something like
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<artist>
<name>Various Artists</name>
<musicBrainzArtistID>89ad4ac3-39f7-470e-963a-56509c546377</musicBrainzArtistID>
<sortname></sortname>
<born></born>
<formed></formed>
<biography>Various Artists often abbreviated as VA or V/A is a term used by the music industry for releases (singles or albums) that contain collaborations. Rather than listing the many individual singers or artists being credited individually, the name Various Artists is used instead.
Aggregated compilation albums containing tracks from a number of artists can also be credited to Various artists. Various Artists compilation albums are often compiled from a particular musical style or period to another.
There are also charity records released that may use the term rather than mentioning specific artists, e.g. USA for Africa or Band Aid.
Another use for Various Artists is a specific artist "and Various Artists" or "featuring Various Artists". This is most common in remixes where there are many releases using the formula, like Rihanna ft. Various Artists for remixes of "What's My Name?".
This practice is in line with the term "and Friends" like in the song "That's What Friends Are For" credited to "Dionne Warwick & Friends" (rather than various artists).</biography>
<died></died>
<disbanded></disbanded>
<thumb>http://assets.fanart.tv/fanart/music/89ad4ac3-39f7-470e-963a-56509c546377/artistthumb/various-artists-508e5d2db23ad.jpg</thumb>
<path>F:\test artists export\Various Artists</path>
<fanart>
<thumb>http://assets.fanart.tv/fanart/music/89ad4ac3-39f7-470e-963a-56509c546377/artistbackground/various-artists-5075a5c07a2ac.jpg</thumb>
</fanart>
<album>
<title></title>
<year></year>
</album>
</artist>
scott s.
