Full Version: Can't use color hue on FRESH kodi install
So i installed kodi from the play store on my nvidia shield. To be exact it is: Kodi 17.6 Git:20171119-ced5097
Before installing other addons I first installed Nebula skin. The color hue option in Settings/Themes is not working for me. I cant select the option, not even with a mouse.
Is there a way to fix this?
Update, I tested a different android device with fresh kodi and nebula install and the problem still exists. This is definitely something i couldnt have prevented.
The version on github is working:
https://github.com/Tgxcorporation/skin.n...rom-GitHub
Tgx
Thank you for replying. Will update the addon with the github zip. For future purposes : how much time does it usually take for github versions to make it to the kodi repo?
