2018-03-25, 17:27
2018-07-11, 16:41
2018-07-15, 01:55
Try this.
Settings - Interface - Configure Skin - Customise Home Menu - Add New Home Menu (Plus Icon) - Choose Item For Menu - Kodi Command - Quit
You can also then select "LABEL" and retitle Quit to Exit if you want. Use the up/down arrows on the menu list to place where you wish and done.
2018-07-15, 23:48
Or you could just add the "close kodi " add-on as a main menu item , it is much much better than the default exit option , this add-on closes Kodi instantly without any of that annoying lag you get when using the default exit option .
Am not gonna post a link to it on here incase its classed as a 3rd party add-on , but if you google "close kodi plugin " you will find it.
