I use Kodi kodi-20180325-03d453ae-master-arm64-v8a and other ones before on my NVIDIA Shield ,
when i play a movie or tv show after 2-4 seconds the playback stops and i am
back at the movie (tv show) info screen from the skin.
My Logfile
If you need more information, please let me know
Same Problem with fresh (clean) install with kodi-18.0-Leia_alpha1-arm64-v8a when i play a movie after 1-2 seconds the playback stops.Over and over again
And it does not matter if I use the standard skin or another one
Logfile
Neither of you have provided a debug log.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Some Movies work some not here the debug logfile.
My
advancedsettings.
xml works well on 2 other machines and on My Shield before on Kodi 17 and SMPC without problems.
https://paste.ubuntu.com/p/zryzssGRCJ/
I tested the Movies the dont work in Kodi 18 in SPMC one thing i noticed are the fps in kodi goes from 23.4 under 15 and in SPMC the fps are always 23.4-24.4.
I found the Problem but i dont know why maybe some of you know why .
This entry in my advancedsettings.xml
<cache>
<buffermode>1</buffermode>
<memorysize>139460608</memorysize>
<readfactor>10</readfactor>
</cache>
And now are the fps are constant 23.4-24.4
but the same buffer settings work on smpc without problems and a little bit different on 2 zotac zbox with libreelec (kodi 17)
If changing your cache settings helps it, then the problem is probably your network.
Strange but okay
Same network same shield same settings Kodi 18 and spmc.
Kodi 18 with problems smpc all okay.
The settings are from the Kodi wiki
But it's no problem I deleted the cache settings an all is okay.
Thanks for your help!!
