Hi to all
I have a problem about progress tv shows. Appears empty always. Try to update library but nothing happens. Any suggestions please? Movies progress appears correctly. Thanks a lot.
Are your tv shows scraped into the library or do you use Videos>Files to access your tv shows?
yes, scraped into the library
I finally found myself having to see a whole episode from a series to add to the "in progress" list.
Can I change that?
From an entire episode to a few minutes?
such as I can change the resume point from 180 seconds to
in the time I want, for example 30 sec.
