Bought an Azulle Inspire for my dad with an i3-7100U and 4K playback is choppy in Kodi. Running Linux Mint 18.3. Any tips for how to fix it?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Use Kodi v18 - there is no hevc 10 bit support for kodi version 17.x on Linux.
DISCLAIMER: I take no responsibility for what you do on your own system. This is what worked for me.
Add unstable Kodi repository and upgrade to Kodi 18
sudo add-apt-repository ppa:team-xbmc/unstable
sudo apt-get update
sudo apt-get install kodi
Upgrade Linux kernel to Linux 4.15.0-13-generic
sudo apt-get install linux-image-4.15.0-13-generic
Add apt-key to download intel-linux-graphics-installer in Mint
wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-GROUP-KEY-ilg
sudo apt-key add RPM-GPG-GROUP-KEY-ilg
Fake lsb-release to report Ubuntu so the installer works.
sudo vi /etc/lsb-release
#DISTRIB_ID=LinuxMint
#DISTRIB_RELEASE=18.3
#DISTRIB_CODENAME=sylvia
#DISTRIB_DESCRIPTION="Linux Mint 18.3 Sylvia"
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04 LTS"
Download and install updated 64-bit libpackagekit-glib2-18 .deb file required by intel-linux-graphics-installer
wget http://security.ubuntu.com/ubuntu/pool/main/p/packagekit/libpackagekit-glib2-18_1.1.5-2ubuntu1_amd64.deb
sudo dpkg -i libpackagekit-glib2-18_1.1.5-2ubuntu1_amd64.deb
Download, install, and run intel-linux-graphics-installer
wget -O intel64.deb https://download.01.org/gfx/ubuntu/16.10/main/pool/main/i/intel-graphics-update-tool/intel-graphics-update-tool_2.0.4_amd64.deb
sudo dpkg -i intel64.deb
sudo intel-linux-graphics-installer
Reboot
Revert lsb-release changes
Update: So this got one of my 4K movies running smoothly, but another shows mostly bright green with the image barely visible.
Debug Logs:
Movie That Doesn't Work
Movie That Works
One difference I noticed was that the one that works uses ATEME Titan File 3.8.3 (4.8.3.0) and the one that doesn't uses ATEME Titan File 3.8.12 (4.8.12.0).
I told you above your issue. Disable passthrough, update your VAAPI drivers to wsnipex vaapi repository.
Edit: I am confused. From your log both are working the same ...
