2018-04-03, 10:15
Here is quick add-on I created to monitor for a Time Change in KODI.
Once there is a Time Change, the add-on will run a defined function (default=Reboot)
The most common use case is for timezones that change during the year (eg. Daylight Savings).
When the time changes, the EPG times become in-correct in KODI.
The only way to fix this is by either clearing the guide data, or restarting KODI.
This add-on will poll for a time change every 60 seconds.
If it finds a time change, it will run the defined function.
Instructions to install can be found here:
https://www.matthuisman.nz/2018/04/time-...dd-on.html
