Full Version: Wandboard IMX6q
Not sure if im in the right place to post this - sorry if i am.
I'm trying to build kodi on the wandboard quad imx6 board
I get error:
/usr/include/EGL/eglvivante.h
unrecognized platform
I have been hacking this file ever since with no luck.  Is there a way to tell kodi to use the opengl to compile and not egl
im trying to build krypton with cmake.  Everything else compiles right this is the only error which shows up as a very ugly linker error at the end.
Thanks for trying to help
I did get it to compile successfully,  by using #define LINUX at the top of that file.
However, it then threw a really bad linker error
undefined references to a bunch of objects glAttributeARG as an example: I will post exact output in a couple of days
Below is the latest output:
[100%] Built target libkodi
[100%] Built target kodi-libraries
[100%] Linking CXX executable kodi-x11
CMakeFiles/kodi.dir/build.make:524: recipe for target 'kodi-x11' failed
CMakeFiles/Makefile2:739: recipe for target 'CMakeFiles/kodi.dir/all' failed
Makefile:138: recipe for target 'all' failed
build/utils/utils.a(GLUtils.cpp.o):GLUtils.cpp:function LogGraphicsInfo(): error: undefined reference to 'glGetStringi'
build/rendering/gl/rendering_gl.a(RenderSystemGL.cpp.o):RenderSystemGL.cpp:function CRenderSystemGL:Big GrinestroyRenderSystem(): error: undefined reference to 'glDeleteVertexArrays'
build/rendering/gl/rendering_gl.a(RenderSystemGL.cpp.o):RenderSystemGL.cpp:function CRenderSystemGL::ApplyStateBlock(): error: undefined reference to 'glBindVertexArray'
build/rendering/gl/rendering_gl.a(RenderSystemGL.cpp.o):RenderSystemGL.cpp:function CRenderSystemGL::InitRenderSystem(): error: undefined reference to 'glGetStringi'
build/rendering/gl/rendering_gl.a(RenderSystemGL.cpp.o):RenderSystemGL.cpp:function CRenderSystemGL::InitRenderSystem(): error: undefined reference to 'glGenVertexArrays'
build/rendering/gl/rendering_gl.a(RenderSystemGL.cpp.o):RenderSystemGL.cpp:function CRenderSystemGL::InitRenderSystem(): error: undefined reference to 'glBindVertexArray'
build/rendering/gl/rendering_gl.a(RenderSystemGL.cpp.o):RenderSystemGL.cpp:function CRenderSystemGL::ResetRenderSystem(int, int): error: undefined reference to 'glBindVertexArray'
build/rendering/gl/rendering_gl.a(RenderSystemGL.cpp.o):RenderSystemGL.cpp:function CRenderSystemGL::ResetRenderSystem(int, int): error: undefined reference to 'glDeleteVertexArrays'
build/rendering/gl/rendering_gl.a(RenderSystemGL.cpp.o):RenderSystemGL.cpp:function CRenderSystemGL::ResetRenderSystem(int, int): error: undefined reference to 'glGenVertexArrays'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::~CRenderCaptureGL(): error: undefined reference to 'glDeleteQueriesARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::~CRenderCaptureGL(): error: undefined reference to 'glBindBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::~CRenderCaptureGL(): error: undefined reference to 'glUnmapBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::~CRenderCaptureGL(): error: undefined reference to 'glDeleteBuffersARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::BeginRender(): error: undefined reference to 'glBindBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::BeginRender(): error: undefined reference to 'glBufferDataARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::BeginRender(): error: undefined reference to 'glDeleteQueriesARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::BeginRender(): error: undefined reference to 'glGenBuffersARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::BeginRender(): error: undefined reference to 'glBeginQueryARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::BeginRender(): error: undefined reference to 'glGenQueriesARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::ReadOut(): error: undefined reference to 'glBindBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::ReadOut(): error: undefined reference to 'glMapBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::ReadOut(): error: undefined reference to 'glUnmapBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::ReadOut(): error: undefined reference to 'glGetQueryObjectuivARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL:TongueboToBuffer(): error: undefined reference to 'glMapBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL:TongueboToBuffer(): error: undefined reference to 'glUnmapBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(RenderCapture.cpp.o):RenderCapture.cpp:function CRenderCaptureGL::EndRender(): error: undefined reference to 'glEndQueryARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL:Big GrineleteYV12Texture(int): error: undefined reference to 'glUnmapBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL:Big GrineleteYV12Texture(int): error: undefined reference to 'glDeleteBuffersARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateYV12Texture(int): error: undefined reference to 'glGenBuffersARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateYV12Texture(int): error: undefined reference to 'glBufferDataARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateYV12Texture(int): error: undefined reference to 'glMapBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateYV12Texture(int): error: undefined reference to 'glDeleteBuffersARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL:Big GrineleteNV12Texture(int): error: undefined reference to 'glDeleteBuffersARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateNV12Texture(int): error: undefined reference to 'glGenBuffersARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateNV12Texture(int): error: undefined reference to 'glBufferDataARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateNV12Texture(int): error: undefined reference to 'glMapBufferARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateYUV422PackedTexture(int): error: undefined reference to 'glGenBuffersARB'
build/cores/VideoPlayer/videorenderers/videorenderers.a(LinuxRendererGL.cpp.o):LinuxRendererGL.cpp:function CLinuxRendererGL::CreateYUV422PackedTexture(int): error: undefined reference to 'glBufferDataARB'
collect2: error: ld returned 1 exit status
make[2]: *** [kodi-x11] Error 1
make[1]: *** [CMakeFiles/kodi.dir/all] Error 2
make: *** [all] Error 2
and:
output of glxinfo:
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read
client glx vendor string: Vivante Corp
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX version: 1.4
GLX extensions:
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_make_current_read
OpenGL vendor string: Vivante Corporation
OpenGL renderer string: Vivante GC2000
OpenGL version string: 2.1 2.0.1
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_imaging, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_pixel_buffer_object, GL_ARB_shader_objects,
GL_ARB_texture_compression, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_shader, GL_ARB_window_pos, GL_ATI_draw_buffers,
GL_ATI_element_array, GL_ATI_separate_stencil,
GL_ATI_texture_env_combine3, GL_ATI_vertex_array_object, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_color_table, GL_EXT_convolution,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_object, GL_EXT_histogram, GL_EXT_packed_depth_stencil,
GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_stencil_two_side, GL_EXT_subtexture, GL_EXT_texture,
GL_EXT_texture3D, GL_EXT_texture_array, GL_EXT_texture_buffer_object,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_timer_query,
GL_EXT_vertex_array, GL_NV_texture_rectangle, GL_SGIS_generate_mipmap,
GL_SGIS_texture_lod, GL_SGI_color_matrix, WGL_ARB_extensions_string,
WGL_EXT_extensions_string, WGL_EXT_swap_control
thank you!
Turns out i have opengl 2 installed not 3.  I'll get back later once i get that in right!
