2018-04-04, 06:59
2018-04-04, 07:03
That is a Microsoft Database file isn't it?
There is nothing to play.
2018-04-04, 07:58
Its mpeg-dash file.
2018-04-04, 08:06
What happens when you try?
2018-04-04, 08:13
I am not sure how to start.
Do I just send that link to player?
ie. This is the link I want to play in Kodi 17.
http://download.tsi.telecom-paristech.fr...-AV-BS.mpd
How do I start ? I am not sure.
2018-04-04, 18:23
2018-04-05, 01:04
(2018-04-04, 08:13)jchirag Wrote: [ -> ]I am not sure how to start.If you just want to play from Kodi Videos menu, then you create a test.strm file with the below contents and select it from Kodi videos menu
#KODIPROP:inputstreamaddon=inputstream.adaptive
#KODIPROP:inputstream.adaptive.manifest_type=mpd
http://download.tsi.telecom-paristech.fr/gpac/DASH_CONFORMANCE/TelecomParisTech/mp4-live/mp4-live-mpd-AV-BS.mpd
However if you are doing from within an addon, then to the listitem you need to add
listitem.setProperty('inputstreamaddon', 'inputstream.adaptive')
listitem.setProperty('inputstream.adaptive.manifest_type', 'mpd')
listitem.setMimeType('application/dash+xml')
listitem.setContentLookup(False)
2018-04-05, 09:29
Thanks will try that.
Also one more question, can I pass any header information.
ie. X-Forwarded-For or something else ?
If so, how ?
If so, how ?
2018-04-07, 03:54
(2018-04-05, 09:29)jchirag Wrote: [ -> ]Thanks will try that.Yes you can pass headers
If so, how ?
In STRM file, as below, any combination of headers
#KODIPROP:inputstream.adaptive.stream_headers=Referer=blah&User-Agent=Blah
And in python code as follows
listitem.setProperty('inputstream.adaptive.stream_headers', 'Referer=blah&User-Agent=Blah')
2022-04-24, 17:43
hi, i know its an old post, but do you have an example of how to add an x forwarded to an mpd?
wha should the header be?
thanks
thanks
2022-04-28, 13:54
(2022-04-24, 17:43)markeymark Wrote: [ -> ]hi, i know its an old post, but do you have an example of how to add an x forwarded to an mpd?
thanks
This is how I have added
#KODIPROP:inputstream.adaptive.stream_headers=X-Forwarded-For=182.77.85.84
http://xxxxxxx.mpd
2022-04-28, 13:55
(2022-04-28, 13:54)jchirag Wrote: [ -> ]Thanks going to try this on my streams(2022-04-24, 17:43)markeymark Wrote: [ -> ]hi, i know its an old post, but do you have an example of how to add an x forwarded to an mpd?
thanks
http://xxxxxxx.mpd
