2018-04-04, 14:22
Hello,
I bought an AndroidTV (KingBox K3 - CPU S912 octacore Cortex A53 @ 2GHZ - Mali-T820 GPU - 2GB RAM - 16GB ROM), but unfortunately the default video player of Kodi creates micro shots on all the movies (.avi, .mp4, .mkv).
I tried to remove the two hardware accelerations proposed (mediacode surface and mediacode), but the result does not change, the film is always seen in steps.
The TVbox player, but also MXplayer (setting the hardware codec) and VLC, smoothly display all the movies.
Setting kodi on one of the above readers as external, the film is fluid, so I do not think it is the fault of the memory occupied by Kodi.
Can I solve it in any way?
Thank you
Thank you
