2018-04-04, 14:39
Kodi 17.6.
DTS-MA works fine until Shield sleeps. Upon resume, DTS-MA doesn't work and my AVR shows "PCM" on stream info, with no audio. If I select DTS-5.1 or another track it plays, but DTS-MA (and probably Dolby True HD) won't work again until I kill the Kodi app and restart it. Then it's fine again.
So I've had to cobble a macro together with a Harmony remote to double-click home button and kill apps when turning off the system, and setting a "quit app" action in Kodi after 10 minutes of inactivity, and setting a longer "sleep" time for Shield in order to try to avoid the condition.
Same situation on both Shield TV (2017 models) units I have, in 2 different systems.
Tried all audio settings that I could think of - no change.
BTW, I'm using passthrough set in Kodi, and Fixed Volume in Shield.
