Full Version: Full Channel List not downloading
New into using PVR. I have 2 R PIs running, both have same issues with 2 different setups (1 OSMC 1 OpenElec).
i have a subscribed M3U that fully works in VLC on PC but on Kodi I only get about 614 of the 2500 channels, 400 of these are VOD and they wont work in Kodi, the remaining are live TV and they work.
I dont understand why VLC receives 100% and works 100% but Kodi only receives 614 of the 2500 channels the same in each box??
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
