When posting text snippets or log files, use a text upload website like https://paste.ubuntu.com/
When it is about a debug log, always provide the FULL kodi.log file, not just a couple of puzzle pieces.
thanks, i will submit complete log
Stop posting logs at our forums. Use a paste-service like mentioned above
And get rid of banned add-ons
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Thread moved to video add-on support.
That log doesn't have debug logging enabled.
You may be better contacting the author ( @
luivit ) directly or via Github if there's no response here.
This thread may also relates to that addon?
I'm Testato coauthor of RivediLa7 with Luivit
We cannot solve this problem so asked here for some help.
The thread that you mentioned is about another La7 addon by nightlyer, it is a different addon.
I will post new log with degub enabled or you can try yourself by using the addon, you can install from Kodi official repo because this problem is present also on the old version
news ?
we are on the official Kodi repo too, may we have some help on this problem ?
thanks for the Update, it would be a great if the Same Person who worked in this, can have a look at the mediaset addon, it needs a little Bug fix.
thanks in advance
(2018-04-16, 16:12)testato Wrote: [ -> ]news ?
I think it was a problem with HLS streams. Can you check if the problem persists using the current nightly builds? Cheers
(2018-04-18, 00:21)enen92 Wrote: [ -> ]I think it was a problem with HLS streams. Can you check if the problem persists using the current nightly builds? Cheers
hi enen92
i tested it with KodiSetup-20180421-121cd5ce-master-x64.exe
The problem now is changed:
with kodi17 when you start any video, first runs for one / two seconds, then stops and auto restarts from the beginning
with kodi18 the video loose the first two seconds
you can check the problem by comparing the same video by starting it on the plugin and the online link, for example this loose the initial theme song
- Online:
http://www.la7.it/tgla7/rivedila7/tg-la7...018-239824
- Plugin: La7-La7d --> News --> TG LA7 --> 22/04/2018
