I'm having playback issues with 1080p @ 60fps content when DXVA2 is enabled. The video appears to run at a lower speed lagging behind the audio and eventually it looks like the playback is restarting to resync.
Build I'm testing with now is 18.0-ALPHA2 Git:20180408-ff02b71bb0. The build I had previously was 18.0-ALPHA2 Git:20180327-d6910ff8d7
Debug Log -
https://pastebin.com/uUYC59AY
Sample file -
http://distribution.bbb3d.renderfarming....normal.mp4
I am having a similar issue on my Windows 7 x64 machine running Kodi x64
KodiSetup-20180408-ff02b71b-master-x64.exe. This seems to happen only with content that is 720i or 720p - 1080p or 1080i content runs fine.
If I turn off "Sync playback to display" the issue goes away. This issue has been present since Alpha1 for me, but I have not had an issue with my initial v18 or previous versions (<v17) of Kodi.
If I pause the video, as you can see in the sample video below, the video continues to play at the wrong speed.
Any ideas?
Sample Video of Issue: Sample Playback mp4
Debug Log: https://pastebin.com/uUYC59AY
I am still having this issue on today's build:
KodiSetup-20180409-9f206f47-master-x64.exe
If I turn back on "Sync playback to display" and turn off DXVA2, all content plays as expected. If I turn on DXVA2, content that is less than 1080p has the issue in my OP above.
(2018-04-10, 02:43)JoshDi Wrote: [ -> ]I am having a similar issue on my Windows 7 x64 machine running Kodi x64 KodiSetup-20180408-ff02b71b-master-x64.exe. This seems to happen only with content that is 720i or 720p - 1080p or 1080i content runs fine.
Any ideas?
Sample Video of Issue: Sample Playback mp4Debug Log: https://pastebin.com/uUYC59AY
1.
Adjust display refresh rate is preferred than
Sync playback to display.
2. I see nothing wrong in your log.
3. I can't reproduce the issue with less power (than yours) HW
(2018-04-11, 08:45)afedchin Wrote: [ -> ] (2018-04-10, 02:43)JoshDi Wrote: [ -> ]I am having a similar issue on my Windows 7 x64 machine running Kodi x64 KodiSetup-20180408-ff02b71b-master-x64.exe. This seems to happen only with content that is 720i or 720p - 1080p or 1080i content runs fine.
Any ideas?
1. Adjust display refresh rate is preferred than Sync playback to display.
Were you able to repro the issue I'm having?
Any ideas?
Was DXVA2 available in v17 of Kodi? I believe it was and I never had any audio/video sync issues....
Any ideas?
Since October 2017 v18 builds the issue is still present and during all later nightlies. Sync playback to display works but is not the solution because the audio passthrough don't work anymore.
Yes, anyone have any ideas on how to resolve this? It is quite frustrating!
(2018-04-13, 15:05)JoshDi Wrote: [ -> ]Yes, anyone have any ideas on how to resolve this? It is quite frustrating!
Don't use alpha build, use the last release instead.
The issue is something related to buffering. If I have DXVA2 enabled from the start of the video, I experience the playback issues in my video. If I start the video with DXVA2 disabled and then turn it on in the middle of a clip, the issue only presents itself if I pause the clip for a long time.
enabling/disabling DXVA2 during playback has effect only for next video. it's not possible to start playback with hw decoding and continue without it and vice versa
afedchin have you been able to repro the issue I originally posted about? I believe it is unrelated to Joshdi's issue
(2018-04-17, 17:55)drpizznock Wrote: [ -> ]@afedchin have you been able to repro the issue I originally posted about? I believe it is unrelated to Joshdi's issue
Unfortunately no, I wasn't able to reproduce the issue.
afedchin how can we help you reproduce the issue or debug further?
(2018-04-18, 15:10)JoshDi Wrote: [ -> ]@afedchin how can we help you reproduce the issue or debug further?
I'don know, really. I have less powerfull hw than yours. May be some GPU power save mode is enabled on your system.
