Full Version: No Sound "electriQ 55 Smart Tv" Kodi v17.6 "No Sound at all"
I have electriQ 55" 4K Ultra HD LED Smart TV with Android - Model eiq-55UHDT2SM
I have installed the latest Kodi Kodi v17.6 "Krypton". I cannot seem to get the sound to work on any kodi build , Dose anyone have the same Issue with this smart tv has anyone found a solution. i would be so grateful.
Tried Tweeking settings
https://kodi.wiki/view/Audio_quickstart_guide
With no luck at all
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Problem Solved ....
Installed kodi 16  There was sound
then I installed Kodi 17.1
That solve the sound issue on Kodi
Have not Tried Kodi v17.6
But i am happy with 17.1 With sound any build
