Full Version: Titan M O D ( last Updated 19-12-2019)
(2019-12-11, 10:39)Aphykit2006 Wrote: [ -> ]
(2019-12-10, 21:32)Fuchs2468 Wrote: [ -> ]
(2019-12-10, 21:10)rox56 Wrote: [ -> ]That makes sense - I did start with one of the presets and then started changing things. I thought I was going crazy!
Thank you for your help and time, appreciate it!
No problem  Smile
@Fuchs2468
Thank you for this clearly detailed information.
I tested too, but it did not work. I found why ....
 @ro"rox56"
Need =>  footer panel color
Now :
Regards.
in case of short time,
i understand you like to change the color of tags shown below each movie.
if so, you need to go
generell colors - define " label overlay on poster and thumbs tags color"
sorry, not more time to go over other posts atm..
(2019-12-11, 13:37)mardukL Wrote: [ -> ]
(2019-12-10, 21:32)Fuchs2468 Wrote: [ -> ]No problem  Smile
@Fuchs2468
 @ro"rox56"
Now :
Regards.
Hello.
Thx.
It's perfect for me.
I'm just looking for animated poster / fanart. (See previous post) . But this bug is not urgent.
Have a good day.
@Aphykit2006 good catch, thank you! That fixed it for me.
I have a little update (song titles TITAN-search) for everyone who doesn't want to wait for the official update or asked for it.  (post: 1493)
here are the files: song_titles_titan_search.zip
- unzip zip
- Custom_1100_Search.xml and IncludesCustomSearch.xml in " \ addons \ skin.titan.mod.beta.leia \ 1080i " replace
Have fun while testing. Smile
1. Picture:
2. Picture
3: Picture
@Fuchs2468
Thank you.
As you seem to know this mod well, would you have an idea for my animated poster problem?
https://forum.kodi.tv/showthread.php?tid...pid2906629
Regards
I seem to be having a problem since Titan updated. Now on my widgets, the first row, the header seems larger so it covers the top of my widgets. Anyone know how I can change this while keeping these widgets ?
(2019-12-15, 11:36)AntonyB Wrote: [ -> ]I seem to be having a problem since Titan updated. Now on my widgets, the first row, the header seems larger so it covers the top of my widgets. Anyone know how I can change this while keeping these widgets ?
Take a screenshoot so that you know exactly what you mean.
This is the best skin for kodi, thx for all the work.
One question, is it possible to see library totals on
Homescreen or in movie/ serie section? (Netflix view)
So i can see how many movie and series i have.
Thx
(2019-11-27, 04:15)t123thomas Wrote: [ -> ]Hi, I just want to report this issue, each time that I play a tv show it flashes the title of the TV show on each of the episode, this only happens in the recent beta note The Musketeers
If you are referring to the logos over your episode thumbnails.. this happens when you haven't selected the landscape thumbnail art. Even though the skin finds and clearly shows them.. it's not set.. This happens on movies as well.
(2019-12-09, 11:16)Aphykit2006 Wrote: [ -> ]@mardukL
Hello
I have a problem with posters and animated backgrounds.
I am in Mysql with network drives.
The animations only work if I select them manually (without using choose art ou Artwork beef)
Can you do something?
Thank you in any case for the exellent work.
Regards.
Its because, the contextmenu is related to artwork beef, and the get art button in videoinfo is kodi default which arent give acces to keyra db, but you can set animated/gif image if its stored local.
BUT , you can make the artwork beef button visible. To get it work in VideoInfo
->Settings -> Media Library Views -> under the 'Header' VIDEO INFO' you ll find an option to called "select which buttons to show in videoinfo"
(2019-12-09, 19:23)simtaj Wrote: [ -> ]I have Netflix origin layout with widgets on homepage.
Studio logo shows immediatly, but for ratings I must wait for some seconds.
Can you help me how to get rating faster like Studio logo, which is super fast.
Thank you for your work!
Its related to skinhelper service.
Theres nothing i can do about, once the ratings are cached it should be a bit faster to show up, but dont expect ms.
(2019-12-13, 01:24)Fuchs2468 Wrote: [ -> ]I have a little update (song titles TITAN-search) for everyone who doesn't want to wait for the official update or asked for it.  (post: 1493)
- unzip zip
1. Picture:
2. Picture
3: Picture
Thanks, merged it a few days ago on git, also added your provided theme.
(2019-12-15, 18:21)bacardicola Wrote: [ -> ]This is the best skin for kodi, thx for all the work.
Thx
I am unsure if i will add this here. As it was not supposed to use a header.
But maybe sometime ;-)
But very low Priority for now.
(2019-12-16, 06:09)RayDawGGG Wrote: [ -> ]
Will take a look.
(2019-12-16, 13:00)mardukL Wrote: [ -> ]
Hello
Regards.
Hello.
Thank you for the feedback.
Precisely, it is from the same animated poster.gif file downloaded by artworkbeef and located on a network disk with the covers.
In one case the animation works (but manual selection), in the other case (via the AB button, or in automatic mode: no ..
But the rest works well, so it's not that important.
PS: I know the way for the buttons , same issue.
Ps2: if you want to put my color themes in the next delivery: no problem (I would be proud)
Have a good day. :-)
