(2019-12-31, 09:20)xbmclinuxuser Wrote: [ -> ] (2019-12-27, 22:07)mardukL Wrote: [ -> ]I removed 'artwork downloader' - support.
you'll have to move over to 'artwork beef'.
I'm having the same problem that others are reporting. I do wish you'd reconsider not supporting Artwork Downloader; it always worked and worked well, and having great artwork was always one of the primary motivations for using the Titan skin. Artwork Beef not only has a stupid name, it just isn't pulling in new logo artwork. And I do have all the latest versions of the addons Fuchs2468 mentioned in his post above, in fact any time an update is available I generally let it update as soon as I see it.
Artwork Beef is a full replacement for Artwork Downloader and also offers
some more options.
There is really no disadvantage .
in case of shorttime, just is the link to the forum thread.which includes all needed 'sub'links.
https://forum.kodi.tv/showthread.php?tid=258886
which custom art are you talking about?
its also possible to define them within the addon settings.
(2019-12-30, 15:42)UbuntuUser Wrote: [ -> ]Getting PVR artwork no longer works in the new version, if I try to do it auto or manual I get a Skin Helper Error.
https://paste.kodi.tv/ehayikosen.kodi
Thanks in Advance for any help, UbuntuUser
mardukL any idea why PVR art is not working?
Thanks in advance, UbuntuUser
(2019-12-31, 18:28)UbuntuUser Wrote: [ -> ] (2019-12-30, 15:42)UbuntuUser Wrote: [ -> ]Getting PVR artwork no longer works in the new version, if I try to do it auto or manual I get a Skin Helper Error.
@mardukL any idea why PVR art is not working?
i need to take a look, if its worked before i would put it skinhelper.service /metadatautils in the shoes.
which artwork is missing in which case/place ?
may its not need a helper addon.
(2019-12-31, 22:30)mardukL Wrote: [ -> ] (2019-12-31, 18:28)UbuntuUser Wrote: [ -> ] (2019-12-30, 15:42)UbuntuUser Wrote: [ -> ]Getting PVR artwork no longer works in the new version, if I try to do it auto or manual I get a Skin Helper Error.
When you are in PVR recordings or Timers you see art for them both if you don't aka a new show you can go to artwork in the menu and say auto or manually download, and in the past that has always worked. Now I get an error message at the top of the screen that says Skin Helper error check log for details. I posted the details of the error in the OP but I will put the link here again.
Thanks for your help, UbuntuUser
(2020-01-01, 01:26)UbuntuUser Wrote: [ -> ] (2019-12-31, 22:30)mardukL Wrote: [ -> ] (2019-12-31, 18:28)UbuntuUser Wrote: [ -> ]@mardukL any idea why PVR art is not working?
ok. thanks.
i'll try to get an solution.but no promise, as i dont have an pvr/iptv client.
but its related to metadatautils.
did you set your api keys in the settings?
I also was having an issue with the SHS not working correctly for PVR artwork on my own skin mod, but after a quick read yesterday I downloaded updated versions of the
script.module.metadatautils and
script.module.thetvdb modules. Once installed, SHS started working again. Think there is also an update available for Marcel's beta repo as well.
Hope this helps
(2020-01-01, 16:56)mardukL Wrote: [ -> ] (2020-01-01, 01:26)UbuntuUser Wrote: [ -> ] (2019-12-31, 22:30)mardukL Wrote: [ -> ]i need to take a look, if its worked before i would put it skinhelper.service /metadatautils in the shoes.
ok. thanks.
Yes api keys are set, and I still get same error. Thanks I really appreciate you looking into this, I really miss this feature.
Thanks, UbuntuUser
(2020-01-01, 18:03)Dumyat Wrote: [ -> ]I also was having an issue with the SHS not working correctly for PVR artwork on my own skin mod, but after a quick read yesterday I downloaded updated versions of the script.module.metadatautils and script.module.thetvdb modules. Once installed, SHS started working again. Think there is also an update available for Marcel's beta repo as well.
Hope this helps
I have the newest versions and it is still is giving me the error.
Thanks, UbuntuUser
Hi
Does the current version work with Kodi v19 aka Matrix and Python 3?
(2020-01-01, 19:49)UbuntuUser Wrote: [ -> ] (2020-01-01, 16:56)mardukL Wrote: [ -> ] (2020-01-01, 01:26)UbuntuUser Wrote: [ -> ]When you are in PVR recordings or Timers you see art for them both if you don't aka a new show you can go to artwork in the menu and say auto or manually download, and in the past that has always worked. Now I get an error message at the top of the screen that says Skin Helper error check log for details. I posted the details of the error in the OP but I will put the link here again.
ok. thanks.
Thanks, UbuntuUser
Honestly I would be happy even if there were someway to put the art in directories with the name of the show and then in each directory there were a poster.jpg, fanart.jpg, logo.png. and it would pick it up for the show, based on the folder having the same name as the show. If this would be possible please let me know. I just really want the artwork back, if that would be possible.
Thanks in Advance, UbuntuUser
Quick question - in the Netflix showcase view for the mainscreen, I cant get the other ratings to show besides IMDB and TheTVB. If I ask information (I) in a widget it pops up metacritic and rotten tomatoes, just when it goes to the info screen. Is this known or did I miss an option somewhere?
(2019-12-20, 11:02)mardukL Wrote: [ -> ] (2019-12-20, 00:28)DoctorBR Wrote: [ -> ]@mardukL, is it possible to use phil65 ExtendedInfo Script on your Skin?
actual yes, but in future i tend to replace it with
embuary info
https://forum.kodi.tv/showthread.php?tid=346034
mardukL, I'd like to rate the movies I watch on your Skin, so these ratings sync with my TMDb account, just like using the Estuary (image below).
What do I need to do to use ExtendedInfo Script on your Skin?
(2020-01-02, 19:04)Thugbear Wrote: [ -> ]Quick question - in the Netflix showcase view for the mainscreen, I cant get the other ratings to show besides IMDB and TheTVB. If I ask information (I) in a widget it pops up metacritic and rotten tomatoes, just when it goes to the info screen. Is this known or did I miss an option somewhere?
It is currently not skinned, didnt find a good position for them atm, so i left them out for now.
Also studio logo is always monochrome, and seasons/episodes are not be able to toggle watchhed/unwatched.
(2020-01-03, 02:49)DoctorBR Wrote: [ -> ] (2019-12-20, 11:02)mardukL Wrote: [ -> ] (2019-12-20, 00:28)DoctorBR Wrote: [ -> ]@mardukL, is it possible to use phil65 ExtendedInfo Script on your Skin?
embuary info
@mardukL, I'd like to rate the movies I watch on your Skin, so these ratings sync with my TMDb account, just like using the Estuary (image below).
there should be an option in skinsetting - library - videoinfo .
but extended info will be replaced sometime with embuary info.
but there are addons which can sync/set ratings to trakt,tmdb, etc... via contextmenu/after watch
may test
script.userrating
https://kodi.tv/addon/scripts/user-rating
or
script.afterwatch
https://forum.kodi.tv/showthread.php?tid=162770
(2020-01-03, 03:00)mardukL Wrote: [ -> ]there should be an option in skinsetting - library - videoinfo (...)
mardukL, ExtendedInfo Script (original) does not appear even by changing settings in skinsetting - library - videoinfo ...
what can it be?
