(2020-03-20, 12:51)mardukL Wrote: [ -> ]@charettepa
what are you doin to force your lookup exactly ?
also can you post a log!?
while in the recordings
move onto a specific show
activate the context menu
artwork options
refresh (manual lookup)
it then asks if it is movie or tv show
I select tvshow
then i get a list of possible matches with valid artwork, posters, banners
i am then able to succesfully select the correct one
it then goes back to the recordings where you see the "spinner"
after a few cycles you get the "skin helper service error, check the log for more information"
unfortunately, its running on an adroid shield tv
i do have the ability to view the log
but i dont know how i would get it out to send it to you
i have a log capture addon that shows the error from the log on screen when it happens
it is a python exception
its not long so ill type it out
Error: Exception Thrown
(PythonToCPPException): : -->Python callback/script returned the following error <--
-Note: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error type:<'exceptions,AttributeError'>
Error Contents: 'NoneType' object has no attribute
Traceback )most recent call last
File
"storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/scr
line 28, in <module>
metadatautils.pvr_artwork_option(title,channel,genre)
File
line 145, in pvr_artwork_options
return self.pvrart.pvr_artwork_options(title,channel,genre)
File
line 238, in pvr_artwork_options
self.get_pvr_artwork(title=title,channel=channel,genre=genre,ignore_cache=true,manual_select=false)
File
line 128, in get_pvr_artwork
tvdb_match=self.lookup_tvdb(searchtitle,channel,manual_select=manual_select)
File
line 377, in lookup_tvdb
network=item["network"].lower().replace(" ","")
AttributeError: 'NoneType' object has no attribute
'lower'
---> End of Python script error report <----
